Thats a very hard question to answer as its depends on so many factors....battery condition, flight weight, weather conditions, proper CG setup, prop condition, flying style etc
If I fly full FPV then I land after about 5:30mins. If i fly without camera or FPV then I land at about 7:30mins. If I am hovering around then at least 7mins but if you fly aggressive it can be less than 6mins. You can double up the 2200mAh Lipo and get about 12mins flight but the quad will be very lumbersome in the air and momentom will be your enemy.
Average time is about 5~7mins. Without the camera on this setup I would say you will be looking around the 8minute mark.
Just to put your worries at bay. I sat down with a friend the other night and he brought the exact same setup I added here part from he is making a Hexacopter so we brought 6x motors and 6x ESC and a different frame.
Heck! Look what I've just gone and done. Ordered the frame! Gotta start somewhere...! :) Going to buy bits over time as I look into and learn stuff.
Found this interesting,
- which gives a good overview of stuff.
Pete
@FragglePete brilliant :) did you go for the frame listed above? its a great cheap frame and solidly built with room to expand and modify as much as you like. It would be cool if you could find someone with a CNC to make parts for this frame like a isolation frame to place on the top of frame for the battery and camera can rest on and counter balence eachother but be completly isolated from vibrations, there is a frame called the SpiderX which has the added bit like I am trying to explane...
Spidex Quatricoptero
@JAB1a, as it happens I do have a CNC rig. If someone wants something cut, I'd be happy to do it for the cost of materials + post.
I notice the frame today is listed at £114! Probably the cost of that new fangled friber glass.
Keeping it basic for now, building up the parts slowly as I look into it, but the basics will be based on what you've posted. I just thought if I start getting stuff in then it will spur me on. I think it might worth me buying the radio gear sooner rather than later and look at simulation software to have a practice at flying these things, otherwise the initial crashes could prove expensive. Cash is a big issue here, so if I spread things over time; I'll aim for maiden flight around late spring.
I think the Flight Controller could be an intersting one; the rabbit looks good but reading alot about the new KK2 LCD as well and for the money, it seems great value. I do like the look of the Naza stuff, especially the Return to Home and Fail Safes but obviously so much more money. FPV will be the ulimate goal, I've been wasting so much time just watching FPV videos on YouTube.
Pete
That's gotta be a mistake! I've got one on its way and I paid £14.02
Pete
I have seen some stupid prices on Ebay for this frame, one was for 4hundered something pounds which has no justification. You should be looking at no more the 20quid for the frame.
I suggest a hubsan x4 micro quadcopter for practice, would give you more skills/experience than a simulator and is also SO much fun :)
@pcstru thats wicked to know, I am terrible at CAD but I might try and knock something together if I have the time for you to look at. Thanks for the offer
I did seriously look at buying a cheap Quad to see how I would get on but dismissed it; as I've found with these cheap little helicopters you can buy, once you crash it and damage a prop that's it, game over for it as you can't get spares. Also, did any of you see The Gadget Show a few weeks ago when the bald headed presenter was showing off a cheap quad? He went to take off and the thing just kept going and going with no control whatsoever; comical moment for TV as he handed the remote to a kid and scarpered but would be somewhat embarrasing if that happened to me.
Pete
I'm torn between buying that frame or just buying some square alu tube and lasercutting some acrylic/ply/what have you :)
I'm amazed how cheap the frames on ebay are. I struggle to get the materials for the same cost! On the other hand, if you make your own you know exactly what you are dealing with and can easily mod as needed.
@plexer If you have the skill then definutly make your own. I must say this frame is bullet proof, so make sure you use a very strong material for the center plates. If you have access to a CNC like PCStru then you can get plently of CAD designs for basic quad frames.
@FragglePete The hudsan is a great little quad with some advanced features. there are spares avalible a plenty and even quite a few FPV projects popping up with them. As they come out the box they can lift 20g extra weight, some of the sub-nano cameras and 200Mw Tx's weight about 4g :) I want one for when the weather is too bad outside so I can still get me 'fix'.
I did not see the gadget show sorry. Im sure he was just doing something wrong! lol
@pcstru I would make a copy of the above quadframe but add more surface area top and bottom for mounting things, even if the bottom plate was extended in all directions that would be an improvment
If you can scan (preferable) or take a picture (need focal plane and plate to be parrallell) of the plate and supply a couple of accurate dimensions then mark how you want it modded, I can probably CAD it quite quickly.
Do you have any links for open source drawings for frames?
@pcstru
Most downloaded models tagged with quadcopter - GrabCAD
here is a good place, but not being into CAD I have just ignored most sites like this but I have seen many different CAD designs for many different quads. I do remember somewhere seeing extra parts etc being designed for the x525 frame, I think it was a battery holder on the bottom, I will have a good search. I also know there are alot of files out there for 3d printers and quads, can those files be modified to be used on a CNC (if the part is made of flat sections?)
I am stripping down my frame soon so will get some shots of the plates and add the modifications I think would be good and send them to you, wont be until the weekend I think :) thanks again for the offer of help
@JAB1a, 3d print files can (sometimes) be pressed into service but it's not necessarily straightforward, especially if they are complex. There are also things you can do on a 3d printer that you simply can't do on a 2.5D CNC mill/router. Unfortunately my 3d printer is in need of a new hot end which is in turn waiting for my man cave build to complete so I can unpack and set up my lathe. I did spend many hours painting the new workshop at the weekend so it is all getting tantalisingly close.
Sounds fun I can't currently get in my man cave to work as it's been taken over with all the tut from the storage shed that I'm rebuilding but once that's done I'll be able to make a start.
wow ok I have just found the parts right under my nose on the same site as the radio TX
Spare Parts - Quadcopter X525 Fibre Glass Plate D > Hardware > DIY & Spare Parts > MULTICOPTERS > Main Page > Pyramid Models
"Extra CNC cut Fibre Glass Hardware Plate" would make all the difference for mounting battery and camera too but the top plate needs similar but coming out the sides not front/back.
Yeah, but did you notice this bit: This item is only to be supplied to our customers who have already purchasedeither the X525 Kit or Deluxe version from us, and want to upgrade to the PRO Version.
