Here is our current situation:
As a large secondary school we are not deploying a campus wide solution for wireless. We refuse teacher laptop access to any wireless 'hotspots' we have. These 'hotspots' are only for our 3 trolleys of wireless laptops that are assigned to departments. We have 9 AP's to date currently Netgear WAG102.
This summer decisions have been made to install an additional 2 trolleys making a total of five. This is the direction the SMT are taking to fulfil the ICT requirements for other departments around school. So the number of wireless laptop trolleys we have will only ever go up.
Installing additional AP's here and there is going to get messy! Currently all AP's are not running over PoE - which they are capable of.
So what I want to do is:
1) Install PoE switches in relevant cabs to power AP's
2) Install AP's which will load balance (15 laptops per trolley) and play nice with each other
3) Have some sort of central management so when we grow this wireless implementation it can scale as suitable
Can anyone suggest which PoE switches, AP's and what software/hardware we need to centrally manage all this?
I look forward to the ideas and suggestions people have for this.
Thanks in advance.
Point 3.
With this many APs & Laptops you need a proper manageable wireless solution. It will save you many headaches in the future.
I look after 50 wireless laptops on our network, we have just ordered another 24 plus a few more APs. There is no way I would be able to manage that with off the shelf units.
After a few problems with our wireless stuff I am more than happy with it now. Touch wood, it hardly causes me any problems & the pupils and staff love using it.
Forgot to add the PoE is handy too.
There are many companies offering management solutions as hardware switches and also a combination of hardware and software.
Aruba, Bluesocket, 3com, HP, Airwave many have been discussed.
I am replacing my Buffalo access points with more HP 420's in the summer and using Airwave AMP for the management.
A 50 access point version of AMP is £2500
If you have more than 5 or 6 access points from one cupboard but 8 or less you cna get an HP 2600-8 poe switch.
Otherwise they do a 2626 24 port poe switch.
If you only have the odd one from a cabinet you can buy poe injectors that just insert the juice on the right wires. Be careful that you buy the right ones as cisco use a different pin assignment I believe.
We use entirely Cisco kit here - both for AP's and PoE switches.
Completely reliable and the 1100 series switches are capable of self managing which channel they are on, selecting the most suitable frequency to avoid clashes with other AP's.
Cisco kit also has the advantage of the "x" protocol which does not allow access to the network without the user first being authenticated by the domain. Just in the process of trying to get this set up - so not got a heap of details about the specifics.
Sorry limbo but what are you talking about? the "x" protocol? If you mean 802.1x then any enterprise kit will support this and even some home kit.
Auto selection of channels is not always a good idea.
One issue with it is that it takes the AP time to scan the band and find a frequency for itself.
If there is any interference then it may not pick one and just keep scanning. A DOS attack for your wap if you like.
We're putting in an Aruba system first week of summer break. SO we'll see how that goes the unit can manage the existing Allied Telesyn system we have too. Extricom are good but the APs need to be connected directly to the management console which means you get PoE but you have to buy more managemnet consoles sadly. The Extricom system is useful though as all the APs can be on the same channel without causing interference unlike every other system to date (They've copyrighted the technology). Colubris is another good system. Extreme Networks have their own too. Nomadics are good if you want hotspots as are colubris however Nomadics is in addition to your wireless you'd still need a solution in place.
Wes
I went with the Airwave AMP system as it can manage different makes of AP allthough I am now moving them all to HP 420's it was cheaper than the HP switch offering and I can put other AP's in for the future.
Yes 802.1x - I stopped calling it that because everyone I mention it to just thinks that I am talking about 802.11x which they then confuse with being a new wireless standard.
So I call it the "x" protocol then people want to know more - so thank you for your part in following the script!
As you say - most enterprise kit supports it, but as we know a lot of schools do not use enterprise kit. And I was not saying that cisco are the only people that do it, but that all cisco kit has it as standard.
A lot of people have said this, but personally I have never had a problem with this happening and we have over 50 of them installed at the school.
If it does turn out to be a problem, then you can set it manually - but surely if if can work then this is an advantage of the kit and worth pointing out to people who are asking?
I have a reg edit from one of the microsoft guides to force the computer to autenticate to radius as the machine account rather than the user if you need it. I'm going to use it for wired (in a couple of weeks all going well) and realised that if you lose connection, then it can't reauthenticate if you only allow access to the machine.
For a compleye guide on setting up secure enterprise wifi security using active directory and IAS check out:
http://blogs.techrepublic.com.com/Ou/?p=404
Or the complete guide as a pdf:
http://downloads.techrepublic.com.com/abstract.aspx?docid=277380
It shows how to use the selfssl.exe utility that is part of the IIS resource kit to generate your own self signed certificates for your radius servers.
This gets rid of the need to install the MS CA which is a bit bloated for just identifying radius servers.
Of course if you need all your clients to have their own certs then the CA is the way to go.
I always set my wireless policies in GPO to authenticate as the machine and not reauth as the user.
I'll have to have a look, but I'm not sure if it works for wired connections
In Cisco world you are probably ideally looking at 1240 APs (which have external aerials which provide good coverage and are fairly rugged for schools) and either a Wireless LAN Solution Engine for management if on a budget or Wireless LAN controller if you have a bit more budget.
With the Cisco Kit and compatible laptops (CCX, a lot of laptops support this) it will allow the network to load balance between APs, useful if you are looking to connect more that 10-15 laptops in a room at once.
As said before you def want a manged solution for ease of use etc
Also get pricing from a Cisco Schools Partner, they will provide the best quote.
Happy to help if you want to drop me an email
cheers, Tom
I use a BlueSocket system which is a hardware controller and thin access points offering all the features you suggested. In cabs where there are sufficient PoE devices I use HP 2600-8-PWR switches and 3COM power injectors elsewhere. The 3COM power injectors seem to be very good value for money - any device using the PoE standard should be able to use these (I cannot image that Cisco uses their own 'standard' for PoE).
A lot has been mentioned about these systems on the site before... relative merits and what have you. Aruba, Cisco and BlueSocket seem to be the favourites... it depends on what you like and whether the different license models work for you (personally I like the BlueSocket one off payment and no need for additional licenses as you add more APs or additional features).
I also recommend visiting talking to people with systems or visiting to see them in action. I'm happy to talk about mine.
We use a 3COM WX4400 wireless switch and around 50 2750 3com "thin" access points. Seems to perform flawlessly even with one access point to 20 laptops. All the AP's self tune to avoid clashes with nearby AP's. It's not the cheapest solution by any shot but then again I've not had any issues in the year or so it's been installed :)
Cisco certainly used their own poe standard before it was ratified they used the opposite polarity to what the standard is now.
  • 6 months later...
Hi ToM, i been struggling to find some "Cisco schools partners" Is it possible you could name me a few.
thanks
I am looking at piloting wireless in my school.
I have had bad experiences with wireless from my previous work place. They were using D-Link products.
I getting an idea on prices, i done a few google searches on equipment and they are affordable prices and some completly insane pricing on cisco and the like.
My plan is to pilot our wireless solution in a small area first, if successfull then I will look at a whole school wireless solution. I want to ensure that I buy a solution which is scalable and supports a variety of different and the newest technologies such as VOIP.
I was looking at Netgear products because we have their managed switches and touch wood I have no problems with them and prefer them over Dlink. I attracted with the price as well.
I was looking at either going for 3 WAG102 AP's and some POE netgear switch (8 Port) or I can have a better and more expensive solution where the switches does a lot of managing of AP's using WAGL102 and WFS709TP.
I believe Cisco or HP will be expensive but want to know if there are really expensive or because we are a school we can negotitate better deals.
Any advice would be greatly appreciated
Thanks for all your input guys.
I mean, if we want good coverage for every classroom, how many APs are we looking at for each room to allow up to 30 devices to connect? Once they are on the network, it won't be too bad but my worry is the logging on.
We can only really comment on the usability of a system and the functions that it offers not how many access points etc... you may need as that is best dealt with via a site survey.
It depends on the construction of the walls etc... and the particular flavour of wireless as to how many you will get in the same air space.
But two give you some idea.
I currently manage 9 waps in my amp system I'm adding the others in as I have time.
The current daily usage is that they have used 1.9mbps from the access points so utilization is low.
That is a maximum of 15 clients.
Ben.
  • 6 months later...
I have seen a few comments regarding Extricom and would like to make you aware who we are as we are as here at Cableserve LTD we are specialists within the wireless industry, (we are one of three Extricom premier install partners).
Currently we are working with lots schools, colleges and universities all over the UK installing Extricom and the success has been phenomenal
Below are many (though not all) of the services that we offer, for example.
· Network Cabling Installations
· Wireless Solutions
· Laser Point to Point Links
· Comprehensive Hardware and Software Support Contracts
· Virtual IT Manager Labour Only Contracts
· Service Credit Tickets
· Audio Visual Installations
· Blackberry Installations
· Phone System Installs
· IT Hardware / Software
Here are a few more benefits that using Cableserve would bring you………………..
· FREE REMOTE SUPPORT FOR 90 DAYS – LATEST GEN. “BOMGAR” BOX
· FREE NO-OBLIGATION CABLING SITE SURVEYS
· CABLE INSTALLS FROM £30 PER POINT AND ALL TESTED WITH FLUKE
· FREE DEMONSTRATION OF BEST WIRELESS PRODUCT ON MARKET
· COMMISION CAN BE PAID TO ANY PARTNERS WHO REFER BUSINESS
· FREE NO-OBLIGATION SERVER PROBE’S
If you have any current or forthcoming IT projects that Cableserve would be able to tender for or If you would like me to arrange an on site demonstration or a FREE site survey please do not hesitate to contact me and I would be more than happy to arrange a no obligation appointment with you.
Any questions please ask?
Claire
One system that has not been mentioned is the Motorola solution....as see that you have previously installed low cost wlan. For that reason it is worth looking at Motorola's indoor wlan portfolio as certainly meets the budget requirements.
So much so it is the preferred solution for 90% plus of retailers.
It also meets your requirements as it works via a layer2/3 switch that provides POE.
Regards
intheknow
