tj2419 Posted July 18, 2017 Report Posted July 18, 2017 Our staff are using a website which they are able to access fine. When students try they get a java error. When the staff access it, they get the following prompt and can click run and the application runs in the browser. When students access it they don't get the message and it errors. I'm guessing this will be a GPO blocking java for students but cannot find where it is. Any clues? Thanks
Michael Posted July 18, 2017 Report Posted July 18, 2017 Has the URL been added to the list of exceptions on Control Panel? This can all be scripted (as I've done previously), which makes the solution easier. By default Java exceptions are user based, but you can make them computer based so they apply to any user logging on.
tj2419 Posted July 18, 2017 Author Report Posted July 18, 2017 Has the URL been added to the list of exceptions on Control Panel? This can all be scripted (as I've done previously), which makes the solution easier. By default Java exceptions are user based, but you can make them computer based so they apply to any user logging on. Sorry how/where would I do that? Thanks
Michael Posted July 18, 2017 Report Posted July 18, 2017 As standard (within Control Panel) > Java and there you can specify a list of exceptions (the manual way).
Helen25 Posted July 20, 2017 Report Posted July 20, 2017 Have you got GPO stopping students from running command and install functions too?
kennysarmy Posted July 20, 2017 Report Posted July 20, 2017 Quick and dirty copy and paste from our Tech notes in case this helps: ***************** JAVA normally runs it's security & settings at the user level in order to override this I've created a local folder called: c:\windows\sun\java\deployment In this I've added three files: deployment.config deployment.Properties & exception.sites deployment.config contains the lines: deployment.system.config=file\:C\:/WINDOWS/Sun/Java/Deployment/deployment.properties deployment.system.config.mandatory=true deployment.Properties contains the lines: deployment.user.security.exception.sites=C\:/WINDOWS/Sun/Java/Deployment/exception.sites deployment.browser.vm.iexplorer.locked deployment.browser.vm.iexplorer=true deployment.browser.vm.mozilla.locked deployment.browser.vm.mozilla=true deployment.expiration.check.enabled=false deployment.security.level=HIGH exception.sites contains the line: http://www.gcsecomputing.org.uk/lmc/lmc_java.html I've also created a startup script which does the following: The script is called JavaException.bat and is held here: netlogon mkdir %SystemRoot%\Sun\Java\Deployment copy "\\fp2\SHApps\jre1.7.0_51\deployment.config" %SystemRoot%\Sun\Java\Deployment\ /Y copy "\\fp2\SHApps\jre1.7.0_51\deployment.properties" %SystemRoot%\Sun\Java\Deployment\ /Y copy "\\fp2\SHApps\jre1.7.0_51\exception.sites" %SystemRoot%\Sun\Java\Deployment\ /Y This script is called via a new policy called JavaExceptionCopyFiles
