PotNoodleTech Posted March 26, 2012 Posted March 26, 2012 Hang on this main switch you are using for testing - it may well only have 4 100/1000 ports and the others may be 10/100. If this is the case and your plugging in toa 10/100 port you'll never get more than 12.5mb/s and that's a theoretical maximum. Before you go rewiring rooms tell us exactly the make and model of the switch. I would also say that you would be better of not using the ADSL connection to test but drop a large file on the server and use a stopwatch to time exacly how long it takes to copy to your PC in various locations around the school.
AndyCan Posted March 26, 2012 Author Posted March 26, 2012 Switch is - PLANET GSW-1602SF I think i set the port to auto on Friday and got the same result. I'm waiting for the opportunity to unplug to unplug everything and test wall points indvidually this week. A question about fiber, can i just unplug and re-plug that it like i do ethernet, does it work the same or not as i seem to have it in my head that it doesnt so i'm a bit worried about unplugging and then having no connectivity when i plug back in?
