Google search engine problem PLEASE HELP
Hi Everyone.
i have a problem with Google search.
when you go to the google webpage and then type in a search Eg BBC.
the search then list everything for bbc as per normal, however when you select one to go to it doesnt go that site instead it goes to another nothing to do with the site you want to go to.
so if i searched BBC on google then clicked on the bbc website link in google it goes to another site and it always goes to this particular site no matter what you search for.
what is wrong. Please can someone shed some light on this. is it a virus or something. i have Norton and i have ran this already and all ok.
if you type web site in then its ok.l its only from google.
What is the other site?
You need to find another PC and download a program that will kill it!
I suspect it is MyWebSearch or something similar
