10kva UPS removal, safe disposal and electrical works reqd to put ring back on mains?
hello.
I have a Primary School that needs to have a 10kva UPS removed from protecting a small ring protecting an ICT hub cupboard.
The ring will need wiring back into the main fuse box after.
Does anyone know of a company, preferably through experience, that will do all this and not charge a small fortune?
The school is in the South West
Your county council should have framework contractors, contact your property manager/property surveyor/help desk. You must have someone who normally does your small electrical work? If not, or you're an academy, it's up to someone at the school to engage someone competent, insured, possibly CRB-checked, qualified, etc, etc.
