mikkydoos Posted August 14, 2013 Posted August 14, 2013 (edited) Hi all, Got a recently rebuilt file server - domestic mobo, Adaptec 3805 RAID card - 12 TB, does the job. Just put in a Startech ST1000SPEX42 quad port network card to improve network throughput/failover. Card has 4 X NIC interfaces Chipset - Realtek RTL8111E Server is running Windows Server 2008 R2 Using Realtek Network Diagnostic Utility to perform the teaming of the 4 interfaces Card is IEEE802.3x compliant for LACP Connecting to a Netgear GSM7224 L2 managed switch compliant for LACP Teamed all 4 ports to one virtual adapter, set the IP etc works fine. No VLANs nothing special on the LAN. Now... (please help!)... Works fine with 1 cable connected - Windows reports 1Gb connection Works fine with 2 cables connected - Windows reports 2Gb connection ... Put a third or fourth cable in..... virtual adapter disconnects, 'No network cable connected', no connection. Disabled (and tried unplugging - same result) 2 of the NIC interfaces - connected again on its own. WTF? Switch config? or cr@ppy drivers / Realtek utility?? Is this a 2/2 card (doubt it) - Startech useless, Realtek - forget it. Driving me nuts. Just done an AD x 2 migration from 2003 to 2012, new VMWare setup, monster server, no hitches at all - 2 (short) days . This ones got my goat.... Cheers in advance, Mikky ; ) Have good hols ; ) Edited August 14, 2013 by mikkydoos
mrbios Posted August 14, 2013 Posted August 14, 2013 (edited) realtek card for a server? Wouldn't be surprised if the cheapo junk card is the issue to be honest. Get yourself an Intel quad port card instead, regardless of whether its the cause. Edited August 14, 2013 by mrbios
mikkydoos Posted August 15, 2013 Author Posted August 15, 2013 Would've done if we could have afforded it.
