Intel Management Engine Interface (HECI) driver and imaging
I am building an image for XP (yes, we're still using that here), and one of the drivers I'm working into my image is the one in the title. If I put the drivers from the driver download into a folder, and choose that as the location for the driver manually in Device Manager, it works fine. However, if I bundle that same folder up and use it with the DP_Install_Tool from driverpacks.net, it doesn't work right. Every other driver on the system works fine via this method.
Any ideas what it could be?
