I've got a bit of trouble with Collins GCSE Additional Science on Windows 7. It looks like some kind of standalone flash/shockwave based program. I've installed it on a few machines sucessfully but when it comes to running, one of the machines doesn't do a lot. After the double click theres a couple of seconds of the busy indicator on the mouse pointer and then nothing. There are no events in the event viewer (to be honest I wasn't expecting anything here anyway) and I've had a quick look to see whats happening using Process Monitor. There is a fair old amount of stuff going on in that few seconds but although ProcMon helped in the past, I knew what I was looking for. This time its just a rather large chunk of meaningless data.
I've reinstalled Flash and Shockwave, tried from DVD and network drive just in case the drive was at fault, run as administrator and a few other bits. I'm not sure where to go from here. I feel like a private investigator that has exhausted all leads on a case really.
Does anyone have any pointers either their own experience with a similar problem or a list of things they check when troubleshooting programs?
DAMNIT! I knew I should've opened a ticket for this problem yesterday!!
I had exactly the same thing. What I did was download a copy of procmon, fire it up, filter it to the collins application and one of the last things it did was throw a stack buffer overflow.
I cannot remember what I did to rectify that problem though :( I know that procmon pointed me in the correct direction though... I'll have a rummage around the network around and see if I can recall what I actually did to fix it.
EDIT: It was a quirk in the Intel graphics driver this particular laptop used (Latitude E5400). Update to the latest Intel provided driver and it was all good.
Edited by DrPerceptron
Many thanks for your prompt replies chaps.
Linkazoid, it needed to be on a standalone laptop so no go there unfortunately, that had the same running trouble too.
DrPerception, funnily enough I worked exactly that out with ProcMon by comparing a working install's log file alongside the non working one using Beyond Compare a few minutes before you posted. The working one had a lot more graphics related gubbins going on just after the non worker log had ended. So yes I can confirm that updating to the latest Intel graphic driver fixes this problem. The laptop I had an issue with was a HP Probook 4520s with Intel HD graphics.
  • 1 year later...
