Has anyone had any problems with laptops/pcs sound scheme ? For some strange reason a few machines across the schools i visit, the sound scheme gets changed to a blank custom one and turns all the sound off. Once the rogue scheme has been deleted and set back to windows default everything go back to normal.
At first i thought it was the kids messing about but it seems to be happening more and i cant see 5-10 yr olds knowing how to get round their user rights to get into control panel nevermind editing the schemes.
cheers in advance
You can edit the sound scheme without control panel - if the volume control icon is available down in the system tray, you can often access the sound settings through there depending on GP.
I have experienced bugs with this like you describe, but then I have a script which deletes the default sound scheme for teachers and students, as I got thoroughly sick of hearing the 'logon sound'!
