kixtart problem mapping a drive. Not showing up ish...
Hi All I have a kixtart script that logs my resources drive like so...
;########## NETWORK DRIVES
USE R: "\\PRENTON2\RESOURCES"
USE P: "\\PRENTON2\NETSOFT"
My problem is that they sometimes do not map ish. What i mean is that they usually do but now and again they don't! Everything else in the script runs. If I then go to map the R: drive manually it actually shows that I can't use the r: drive as it's already mapped!
Has anyone else had this problem or could they suggest an alternative way to map this drive?
Just off topic a bit, but can you map drives with kix that are hidden in "my computer"?
Yes, I have our curriculum apps network drive mapped via kix, but hidden from view via GP
Looking further into this it does appear that the mappings are being created. If I try to map a drive to for example r: that it is already mapped! It just isn't appearing in "My Computer"
Can anyone figure that one out?
thanks
