The home pc my family use to play the SIMS game on has a 100GB Hard Drive separated as a 30GB C: OS Drive and a D: Data for the remainder. Was working well. Discovered today that the C: drive was almost full.
Searching through it is clear that the family playing SIMS is the culprit as a lot of data is stored in their Documents and Settings Documents folders on the C: drive.
Plenty of room on the D: drive - is there any way of moving the user Docs and Settings to the D: drive without screwing the games up?
Ah yes silly me forgot to specify the OS!! It's XP Pro. So if i was to do the right click and specify action would the SIMS programme follow the data or would it hang looking for it on the C: drive?
So if i was to do the right click and specify action would the SIMS program follow the data or would it hang looking for it on the C: drive?
It would still look for it on the C: drive.
Thanks for the quick response and multiple answers guys and gals.
Sounds like ultimately the computer is heading toward a wipe and reinstall - several programmes are currently set to run from the D: drive.
Thanks Arthur,
I had a crack before on this machine at resizing the D: to create some free space and expand the C: to fill that with G Parted but couldn't get my head round why it wouldn't work. Should have been easy according to all I read about it but I just didn't get the hang of it. Perhaps I need to have another go with some other software?
Remove the D: partition and then expand C: to fill the rest of the drive.
The alternative would be to find the folder containing the data for the game, move it to D:\ and then create a junction or symbolic link back to the original location using MKLink, Junction or HardLink Shell Extension.
