Hi all,
I'm having trouble getting a VBS script to run with the GPO policy enabled " Run only specified Windows Applications ".
If i disable this policy, the VBS script runs perfectly fine.
Does anyone know what I need to add to the "allow" list get the script to run?
This is what I have in the GPO currently
- examwritepad.exe
- readandwrite.exe
- wscript.exe
I've tried running procmon but can't see anything obvious..
This is the error I get with the policy enabled
Edited by Olliedawg
Are you using a command script as a wrapper for the vbs script, i'm not sure windows 10 will now directly allow .vbs scripts to run from group policy.
I’m running the VBS via a scheduled task (GPO).
the VBS calls a .bat which runs robocopy silently. Without the vbs I get a CMD window when the bat runs on the exam user accounts.
it does work with the run specified applications GPO disabled, however I need this due to exam restrictions. If I manually trigger the scheduled task (with the GPO disabled), it works
Are you explicitly using wscript.exe in the task to run the vbs or just pointing to the vbs? Could it be trying to use cscript or something like that to run the vbs from the task?
try using this command when calling
It is definitely using Wscript.exe I can see that in procmon (even without specifying this explicitly).
On the exam account If i navigate to "windir%\system32\wscript.exe" it opens no issue
I'm wondering if im looking in the wrong place & the issue lies with the .bat
Hi all,
solved it. issue was the .bat all along!! added the .bat to the allowed apps GPO and the script now works as expected spent the past hour troubleshooting this & wasn't even looking at the right thing!:rolleyes:
Thanks all
  • 1 month later...
It sounds like you're dealing with a bit of a headache with the GPO policy. From what you've listed, it seems like you've already added wscript.exe, which should be the executable for running VBS scripts. If it's still not working, maybe try adding cscript.exe as well, since VBS scripts can run with both wscript and cscript. That might do the trick!
