Asus X555LA Laptop - wins 10
Battery Only - Press ON button - nothing - not even logo
Then plug in power - up comes the image of the OS loading (after I pressed the ON button earlier)
Screen works fine while power connected - take out power - screen goes off, but windows still runs in the background
Battery 100%
Just noticed that if I shine a light on the screen while in battery power, then I can see Windows in the background....
External VGA monitor also picks it up on battery power ok
Does the backlight work during POST/BIOS when on battery?
No
Nothing
Asus logo/Post/Bios does not appear when on battery, but windows is loading in background
Okay, that suggests a hardware issue with the screen or the backlight driver hardware. Possibly due to voltage control, maybe weaker battery output. Can you swap another screen in from a similar model as a test?
Just tried another screen and lo and behold, it displays Asus logo on startup while on battery....
Screen at fault...... and not windows
Cheers
