I'm having trouble again with HAP+ (this time with Booking System);
I am trying to set up the booking and it doesn't look right (See Screen 1 in attachments) I have input the correct times from before school to after school, inducing lunch/break times etc.
I've adding (as a test) iPads and 'RM02' (Room 02) for resources but it often disables themselves after I've set it to enable and saved etc.) And generic Art, IT, Science etc. for subjects.
But I can not book anything and it doesn't show me what has been booked and when, I have select one of the hyper links at the bottom of the page and 'book' something but again it shows nothing in the end result.
Am I missing something in the set up?
Update: Ok I can actually book stuff (going on future dates etc.) however it doesn't show it in a time table format like I have seen in other post etc. (Screen 2)
Edited by DPenfold
Update
there was a ~/styles/bookingsystem.css however Ctrl+F5 sadly this has not solve the issue; I have tried replacing the ~/styles/bookingsystem.css file from a back up copy, redownloded v4.6 and v4.5 and still no luck
If you need any coding or files from my end to inspect (when you have the time of course) then please do let me know.
Edit: Reinstalled the entire plugin and the lay out seems to have been fixed, keep you posted if anything else doesn't Work/look right
Edit 2: The Week view appears to be blank (not sure if I am mean to see anything or add anything)
Edited by DPenfold
Update 2
