Power shell run else if authui.dll versions are diffrent.
What am I doing wrong!!!
I am trying to check the versions of the authui.dll and then if they are diffrent it needs to go to else and copy the file accross. The code in the else section works as I used it before but I dont want the script to copy accross the authui.dll on every boot.
# 6.1.7601.18906
Clear-Host
$VersionInfo = (Get-Item C:\Windows\System32\authui.dll).VersionInfo
$FileVersion = ("{0}.{1}.{2}.{3}" -f $VersionInfo.FileMajorPart,
   $VersionInfo.FileMinorPart,
   $VersionInfo.FileBuildPart,
   $VersionInfo.FilePrivatePart)
$FileVersion
$FileVersion2 = 6.1.7601.17514
If ($FileVersion -eq $FileVersion2) {
Write-Host "Already Updated!"
exit
Else
Write-Host "Run script!"
Stop-Process -name explorer
Stop-Process -name LogonUI
takeown.exe /F C:\Windows\System32\authui.dll
icacls.exe C:\Windows\System32\authui.dll /grant Administrators:F
Remove-Item C:\Windows\System32\authui.dll -recurse
Start-Process explorer
Copy-Item -Path .\authui.dll -Destination C:\Windows\System32\
Start-Process LogonUI
$FileVersion
Why are you redoing $FileVersion as wouldn't you wipe what's already in there?
Steve
Actually ignore that, just tried it.
$FileVersion2 = 6.3.9600.17962 is returning blank
If you change it to $FileVersion2 = "6.3.9600.17962" it works on mine
PS C:\Windows\system32>
PS C:\Windows\system32> $VersionInfo = (Get-Item C:\Windows\System32\authui.dll).VersionInfo
PS C:\Windows\system32> $FileVersion = ("{0}.{1}.{2}.{3}" -f $VersionInfo.FileMajorPart,
PS C:\Windows\system32> $FileVersion2 = "6.3.9600.17962"
PS C:\Windows\system32> Write-Host $FileVersion
6.3.9600.17962
PS C:\Windows\system32> Write-Host $FileVersion2
6.3.9600.17962
PS C:\Windows\system32> If ($FileVersion -eq $FileVersion2) {Write-Host "Already Updated!"} else {write-host "no"}
Already Updated!
Edit - Note I changed version to match mine :p
Steve
You can't have the spaces between them:
# 6.1.7601.18906
Clear-Host
$FileVersion2 = "6.1.7601.17514"
exit
else
As an example
Steve
