Need replacement LED panel for Lenovo M92z
I'm in need of a replacement 20" non-touch matte LED panel for a Lenovo M92z AIO computer. The FRU on the original panel is 03T6478. The IBM parts site says to call for a price, which I do, to be told the part has been replaced with FRU 03T6489. They want £240.16 for a new one. This seems rather expensive to me. I've been unable to find one anywhere less extortionate. Anyone have any leads or ideas? Thanks.
That part number ties to this screen LM200WD3-TLF1. LG.Philips LCD LM200WD3-TLF1 Overview - Panelook.com
However as plexer says there should be a sticker on the back confirming this.
The cheapest i can find is about £100 from China, they all seem about about the price you were quoted in the UK, that is if they have stock.
Crazy though, but i wonder if the screen from one of these would fit if you're not keen on buying from China ? LG EN33S 20EN33S 20 inch LED Monitor - 1600 x 900 Resolution, 3.5ms Response | eBay
I've been there with the earlier generation of ThinkCentre AIOs
They are expensive, and we never did find an alternative supplier. Getting the parts from IBM took an age as well - they gave the finance team grief about setting up the account which wasted a lot of time, and then delivery was long winded as well.
I highly doubt the monitor panel would fit - LCDs like that are very fit-specific. The thinkcentre LCDs are very thick compared to most panels and you would have to be lucky for the mounting locations and connections to be correct for a different application.
plexer, here's photos of all the various stickers on the back of the machine and of the panel: imgur: the simple image sharer
difinity and crc-ict, thank you both for your contributions. Looks like getting direct from IBM is our only real option for a guaranteed compatible part.
I'm expecting to at least have to pay VAT plus some fees, even so it should still be cheaper than buying direct from IBM.
My big ticket items luckily have shipped from the UK each time, I've only had to pay once and that was a heavy BGA stencil set. I can't remember exactly but was between £10 and £20 on a £90 purchase.
