amvc Posted September 13, 2011 Posted September 13, 2011 (edited) Hi I have a strange problem, which appears only to have started over the weekend. In short, DHCP requests over wireless are timing out in the majority of cases and so IP addresses are not being renewed. The DHCP server is a Windows 2003 machine. I have installed Wireshark on this, as well as a few wireless clients. What I see is that DHCP DISCOVERS are always received by the DHCP server from the wireless cleints, but DHCP OFFERS are not always received back at the client. They appear to go missing. I suspect a VLAN routing issue perhaps (especially as wired DHCP requests are always dealt with and sent/received correctly), but I can't see what. The wireless module is a HP Wireless Edge XL Module, situated in Port H of a HP 5308xl switch. I have included the config of that switch below. Any help much appreciated. Andrew ----- Startup configuration: ; J4819A Configuration Editor; Created on release #E.11.03 hostname "HP Procurve 5308xl" snmp-server contact "ICT" snmp-server location "" web-management management-url "" module 3 type J4878B module 7 type J4907A module 2 type J4878A module 1 type J4878A module 4 type J8988A module 8 type J9001A module 6 type J4907A module 5 type J4821B interface G16 speed-duplex 100-full exit interface F16 speed-duplex 100-full exit ip default-gateway snmp-server community "public" Unrestricted vlan 1 name "DEFAULT_VLAN" untagged A4,B1-B3,C2-C4,E1-E4,F1-F16,G1-G16 ip address 255.255.252.0 tagged A1-A3,B4,C1,D1,HUP no untagged HDP ip igmp exit vlan 2100 name "VLAN2100" tagged A1-A3,B4,C1,D1,HDP exit lldp auto-provision radio-ports auto-vlan 2100 auto vlan 2 name "VLAN2" tagged D1,F15,HUP exit vlan 3 name "VLAN3" tagged D1,F15,HUP exit fault-finder bad-driver sensitivity high fault-finder bad-transceiver sensitivity high fault-finder bad-cable sensitivity high fault-finder too-long-cable sensitivity high fault-finder over-bandwidth sensitivity high fault-finder broadcast-storm sensitivity high fault-finder loss-of-link sensitivity high fault-finder duplex-mismatch-HDx sensitivity high fault-finder duplex-mismatch-FDx sensitivity high ; Encoded configuration data follows. ; Modifying this data makes the configuration unusable for restores. wireless-services H config "02f0qlNYMpaC3nA4s8Q/ydhF5E1BR0lDADVhMzg" wireless-services H config "0Yzg0MjMwOGU4YWNkZGQ5MmNjMWI4MGNkOTk0AA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAABAAAAAAAAAApwIHv///wAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA" wireless-services H config "QAAAAAAAAAAAAAA" ; End of configuration data. password manager password operator Edited September 13, 2011 by amvc
amvc Posted September 19, 2011 Author Posted September 19, 2011 Fixed it myself. An upgrade to the the 5308xl firmware did the trick. Can't say why though...
