Ive just had to re-build our web server which hosts the intranet. But im having some issues with it..... access internally is fine... but it was set up through ISA server to publish the intranet on the web...
The problem i am getting is that if you type the IP address of the server into a browser window im getting a HTTP 400 - Bad Request error and the same happens if you type in the name of the server..... but all works fine if you try http://intranet. I have done this by putting in an Alias within DNS...
So i am getting a HTTP 400 error when i try to access the site from outside of school......
Ive had a look all over IIS and i cant seem to find where the problem lies...
can anyone help!!!!
