I've got the sound working through headphones by checking the approporiate box in ALSA. However the sound is really badly distorted making it almost useless and I can't find any other settings!
Any ideas?
What protocol are you using to connect to your terminal servers?
If it is ICA, there are several levels of sound quality so you would need to make sure that your application is being published with the desired level.
IIRC, my T5735 terminals required no modification to output 'nice' sound.
Your headphones aren't knackered are they.
For anyone who may have the same problem, we've greatly improved the sound quality by changing the sound setting on the Citrix server from ‘Low Quality’ to ‘High Quality’.
