Bought the linux eee900 but put xp pro sp3 on it. Problem is theres something up with the wireless. It worked after first install but has stopped working now. I have updated the bios and the driver but none of that fixes the problem.
Fn+f2 turns it on and off
Device manager it is working no conflicts
When i enable the connection, the ballon pops up to tell me wireless networks are available, but when i open the Windows wireless thing it says No networks found.
Manually adding the SSID etc doesnt work
I installed netstumbler and it finds the wireless networks no problem, so it seems its a proiblem with the windows utitlity.
Can anyone offer a suggestion about what I might try next?
OK i have fixed this problem. I had disabled some - what I thought unecessary services - seems one of them is key.
I have re-enabled all services and wireless is once again working
