Hi all
Im switching provider and the existing CFS on that runs out next week.(Sonicwall content filtering subscription)
I have been given proxy settings from Netsweeper which I have no issues so far deploying to PC (will be via GPO)
Trouble is I’m finding out whether it’s possible to add this setting into our Sonicwall (the student BYOD goes through a separate port on the Sonicwall seperate to our lan, and Sonicwall acts as dhcp and filter and gateway.
My Sonicwall is managed but the question has been met by radio silence with isp so far...
So before I explore other options, is there a definite yes/no to whether a proxy can be put onto one of the ports on Sonicwall to divert all web traffic to designated filter proxy?
Once this is all done and moved to new isp , all this will be done properly .. we are just setting up filtering to get as through the change over ...
Googling .. it does seem possible but mentions it needs CFS (which will expire?)
Configuring Web Proxy Forwarding Settings
Any help will be hugely appreciated!
