Hi
Was just wondering if anyone knows how to get firmware back onto a z7363 access point, it was halfway through the firmware upgrade when there was a power cut and now the access point cannot talk to the ZD or to a standalone computer. Was wondering if anyone know's how to get the firmware back on these access points when they cannot talk to the network??. Any help will be useful.
Nathan
Whilst the unit is powered up, put a small pin in to the reset hole (may not actually say 'reset') for 12 seconds, that will factory reset the AP, then try again. Hopefully that will help.
nope they are end of life wifi points and from the US so cannot take them back :(. Was see if there was another way to flash the firmware to the device other than via the network
sounds like it's bricked. In these sort of situations (my only experience is with home routesrs) you have to solder on a jtag cable and reflash the eeprom with a compatible tool using a PC.
