The wireless signal from one of our AP's is too strong, it is reaching way beyond the border of our building, is there a way to decrease the power so it's range decreases? Thanks
Configuration > Devices > AP's > Edit (device) > Wireless Interface Edit (interface) > Transmit Power (EIRP)
The Antenna Gain (dBi) is in Configuration > Devices > AP's > Edit (device) > Antenna Properties
Edited by CyberNerd
Hi thanks for that, when I try to change the Gain I get this error message
Error [97.2] This is a fixed antenna. Changing the antenna property is not allowed.
As long as your wifi is secure, is there a problem? If you reduce power, you are likely to reduce throughput and the density advantage which Meru offers.
