    3
    2
    192
Making a Bootable USB Stick
So it seems to be coming more of a common thing now people using USB sticks to install Operating Systems, one thing people seem to have a problem is.. is making the USB Bootable.
Well say no more, it takes about 5 minutes and all you need is command prompt no need for 3rd party software.
~*This only works with Windows Vista/7*~
1) Open Command Prompt
2) cd \ {ENTER}
3) diskpart {ENTER}
4) list disk {ENTER}
5) select disk 1 {ENTER} (if that is your memory stick)
6) clean {ENTER}
7) create partition primary {ENTER}
8) select active partition {ENTER}
9) active {ENTER}
10) format fs-NTFS {ENTER} (may take a few seconds)
11) assign {ENTER}
12) exit {ENTER}
13) Put in your Media (Windows Vista / 7)
14) Go back to Command Prompt
15) D:CD BOOT {ENTER}
D = Optical Drive Letter
16) CD BOOT {ENTER}
17) BOOTSECT.EXE/NT60 G: {ENTER}
G = USB Drive Letter
18) Copy Windows 7 Content to Flash Drive
and there you go, simple put USB stick into your laptop/desktop/netbook and boot from it.
I am just grabbing my notes to create a Gui so you can have mutiple operating systems on 1 disk, and then i'll add that.
Hope it helps
James.
2 Comments
CAM
Good guide and very useful. Same method I used today. :)
Quick warning though, BOOTSECT requires Administrator priviledges and will fail if you open the Command Prompt normally in Windows Vista (or Windows XP as a limited user). Users need to do the BOOTSECT portion of the guide using a Command Prompt opened by right clicking it in the Start Menu and choosing Run As Administrator. Otherwise it just says "Cannot trace a path to disk. Access Denied."
This bit confused the hell out of me until I tried a command prompt with Administrator permissions and my problems were fixed. :)
You can also jsut copy the files to a USB stick and run Setup while logged into Windows Vista if you want to cheat a bit. It copies enough files to C:\ to boot to Windows Setup to finish the job.
Alis_Klar
spotted a typo
in line 10 it should read "format fs=NTFS"
