edutech4schools Posted February 12, 2013 Author Posted February 12, 2013 I am looking at licencing and trying to find the simplest method of doing this. I have purchased some Remote Desktop Services CALs from a our LA and thought the key would be similar to a windows key ie, xxxx xxxx xxxx xxxx xxxx but the license I have been given is xxxxxxx is that correct before I proceed?
tmcd35 Posted February 12, 2013 Posted February 12, 2013 Last time I had to activate a terminal server I had to put in my Microsoft customer agreement number (actually it was the LEA's customer agreement number at the time) and then declare the number of licenses I'd purchased. You can usually find it on any Volume License Invoice. From memory it is a short number in the form xxxxxxx.
edutech4schools Posted February 12, 2013 Author Posted February 12, 2013 I am following this, Configuring a Windows Server 2008 R2 Remote Desktop Services License Server - Techotopia Which seems to suggest I need the long number. Do you have any other info I can follow, the MS site is overly complicated.
tmcd35 Posted February 12, 2013 Posted February 12, 2013 Follow the instructions on that site. On the "Activate Server Wizard" screenshot you should see a pull down for "licence Program". In the example it is showing "Licence Pack (Retail Purchase)". Change this to Volume Licensing and it will ask for your Agreement Number.
edutech4schools Posted February 12, 2013 Author Posted February 12, 2013 Volume Licensing is not listed I have listed, Licence Pack (retail) Open Licence Select Licence Enterprise Agreement Campus Agreement School Agreement Service Provider Licence Agreement Other Agreement
tmcd35 Posted February 12, 2013 Posted February 12, 2013 All the options listed are different types of Volume Licence, other than the first. In most instances it's probably either Open License or Select License - the later being the more popular. It should say on your Invoice or Licence certificate which type it is. If not speak to whomever you bought the licenses from, they should know which type of agreement it was.
edutech4schools Posted February 12, 2013 Author Posted February 12, 2013 OK. Think it will probably be Select but have just sent an email asking. Thanks for your help.
edutech4schools Posted February 12, 2013 Author Posted February 12, 2013 it was select licence. Next question is - user or device licencing. After reading info on MS site I am leaning towards user licencing but never having used this in the real world I would appreciate your advice.
tmcd35 Posted February 12, 2013 Posted February 12, 2013 Typically, if I remember this correctly, you use user licensing if you have more devices than potential concurrent users, and device licensing if you have more users than available devices. 9/10 in a school I'm guessing device licensing is the way to go. It's what I've always used in the past.
edutech4schools Posted February 12, 2013 Author Posted February 12, 2013 This is only for a few staff members who will always be using the laptop they have been assigned. Same number of users as devices.
edutech4schools Posted February 12, 2013 Author Posted February 12, 2013 The majority of environments tend to use Per User TSCALs. This is the case because in most environments individual computers are assigned to a single user, with few cases where multiple users share computers. In this situation, the use of Per User TSCALs makes the administration of licenses easy for the administrator because the number of licenses simply equals the number of connecting users. Going to go with user
SYNACK Posted February 12, 2013 Posted February 12, 2013 Going to go with user Yes that way they can have multiple devices if required.
edutech4schools Posted February 12, 2013 Author Posted February 12, 2013 Could this be my final question? (probably not but hay ho) Installing Sims, should I, Click 'install app on terminal server' in control panel and let it do a full install including dependencies like .net, adobe or install the dependencies first and then click 'install app on terminal server' Does it make a difference?
TheScarfedOne Posted February 12, 2013 Posted February 12, 2013 Could this be my final question? (probably not but hay ho) Installing Sims, should I, Click 'install app on terminal server' in control panel and let it do a full install including dependencies like .net, adobe or install the dependencies first and then click 'install app on terminal server' Does it make a difference? Install newest versions of Adobe, Office and do their updates. The run your SIMs install as normal from SIMsInst is what I do.
edutech4schools Posted February 13, 2013 Author Posted February 13, 2013 Should items like adobe be installed using the 'install app on terminal server method? Not sure what it really does under the hood.
sted Posted February 13, 2013 Posted February 13, 2013 i doubt it makes any difference but i install everything that way to be on the safe side
edutech4schools Posted February 14, 2013 Author Posted February 14, 2013 What encryption level do I choose between FIPS or High? When searching, most posts say you should enable FIPS or High but do not pick one over the other. All clients are 7 pro and I have TLS set as the security layer.
