bassistboy42 Posted October 10, 2008 Posted October 10, 2008 Hi Guys, I've got a problem with the Audio Device on my computer, until fairly recently the device was working fine, but now it doesnt work at all. The device is now in the other devices in the device manager, under multimedia audio controller and has been given this profile by system information for windows: Property Value Device ID PCI\VEN_1039DEV_7012SUBSYS_810F1043REV_A0\3267A616A017 Status 0x01802400 Has Problem Problem 0x0000001c (28) Capabilities 0x00000000 Config Flags 0x00000040 Class Unknown Hardware IDs PCI\VEN_1039DEV_7012SUBSYS_810F1043REV_A0 PCI\VEN_1039DEV_7012SUBSYS_810F1043 PCI\VEN_1039DEV_7012CC_040100 PCI\VEN_1039DEV_7012CC_0401 Compatible IDs PCI\VEN_1039DEV_7012REV_A0 PCI\VEN_1039DEV_7012 PCI\VEN_1039CC_040100 PCI\VEN_1039CC_0401 PCI\VEN_1039 PCI\CC_040100 PCI\CC_0401 Class GUID {4D36E97E-E325-11CE-BFC1-08002BE10318} Location PCI bus 0, device 2, function 7 Bus number 0x00000000 Enumerator name PCI Description Multimedia Audio Controller Driver {4D36E97E-E325-11CE-BFC1-08002BE10318}\0000 Physical Object Name \Device\NTPNP_PCI0004 Bustype GUID {44203042-2046-4245-2043-382031302042} Legacy bus type 0x00000005 Install State 0x00000002 Device Address 0x00020007 Other devices Class Unknown Icon -18 I am currently running Windows XP Personal with an ASUS P5S800-VM motherboard with 2GB RAM, and a 2.93GHz Intel Celeron CPU. If anyone has any ideas about what to do, or anyway to help it would be greatly appreciated! Cheers! Andy
plexer Posted October 10, 2008 Posted October 10, 2008 right click uninstall and reboot? Is it a high def audio device? Ben
bassistboy42 Posted October 10, 2008 Author Posted October 10, 2008 No its not high def tried uninstalling and restarting and it still comes up as a yellow question mark, after reboot anymore ideas?
IanT Posted October 10, 2008 Posted October 10, 2008 ASUSTeK Computer Inc.-Support- Download latest driver there from the ASUS web site 1
bassistboy42 Posted October 11, 2008 Author Posted October 11, 2008 yer it was that the drivers has been deleted... now to hunt down whoever did that thanks for the help
