titch Posted December 6, 2024 Posted December 6, 2024 We have a 1:1 device scheme here and pupils have laptops that are intuned. Senso allows us to visually look at rough laptop percentages but Im trying to create something that each morning will pull down laptop battery percentages so I can mark those that haven't brought their laptops in charged into our behaviour management system which is essentially 2 strikes and a detention. Any Ideas on how I could do this easily? Or possible via senso?
TRSJon Posted December 6, 2024 Posted December 6, 2024 We have a 1:1 device scheme here and pupils have laptops that are intuned. Senso allows us to visually look at rough laptop percentages but Im trying to create something that each morning will pull down laptop battery percentages so I can mark those that haven't brought their laptops in charged into our behaviour management system which is essentially 2 strikes and a detention. Any Ideas on how I could do this easily? Or possible via senso? Afternoon Not via Senso - but.. i've been having to test battery depletion stats for some devices that we are looking to replace. What I've been doing is running this powershell script - which every 5 minutes writes the battery percentage to a text file. I then run VLC with a load of videos on a loop and keep the device running it shutsdown (obviously don't plug the device into the mains)... Maybe you can strip out of the powershell the important part and run it via senso? This is the powershell Set-ExecutionPolicy -ExecutionPolicy AllSigned -Scope Process# Get the device name$deviceName = (Get-ComputerInfo -Property CsName).CsName# Define the path to the log file with the device name$logFile = "C:\batterystat\LogFile_$deviceName.txt"# Infinite loop to keep writing to the filewhile ($true) { # Get the current date and time $timestamp = Get-Date -Format "yyyy-MM-dd HH:mm:ss" # Get the battery status $batteryStatus = Get-WmiObject -Namespace root\CIMV2 -Class Win32_Battery if ($batteryStatus) { $batteryLifePercent = $batteryStatus.EstimatedChargeRemaining $batteryMessage = "$batteryLifePercent% battery life remaining" } else { $batteryMessage = "Battery information unavailable (possibly on a desktop or no battery installed)" } # Construct the log message $message = "Still working - $timestamp - $batteryMessage" # Append the message to the log file Add-Content -Path $logFile -Value $message # Wait for 5 minutes (300 seconds) Start-Sleep -Seconds 300}
TRSJon Posted December 6, 2024 Posted December 6, 2024 Looks like it broke the powershell in the input... Set-ExecutionPolicy -ExecutionPolicy AllSigned -Scope Process # Get the device name $deviceName = (Get-ComputerInfo -Property CsName).CsName # Define the path to the log file with the device name $logFile = "C:\Intel\LogFile_$deviceName.txt" # Infinite loop to keep writing to the file while ($true) { # Get the current date and time $timestamp = Get-Date -Format "yyyy-MM-dd HH:mm:ss" # Get the battery status $batteryStatus = Get-WmiObject -Namespace root\CIMV2 -Class Win32_Battery if ($batteryStatus) { $batteryLifePercent = $batteryStatus.EstimatedChargeRemaining $batteryMessage = "$batteryLifePercent% battery life remaining" } else { $batteryMessage = "Battery information unavailable (possibly on a desktop or no battery installed)" } # Construct the log message $message = "Still working - $timestamp - $batteryMessage" # Append the message to the log file Add-Content -Path $logFile -Value $message # Wait for 5 minutes (300 seconds) Start-Sleep -Seconds 300 }
mavhc Posted December 6, 2024 Posted December 6, 2024 you can use the square bracketed [ code ] and [ / code ] commands to format code 2
titch Posted December 6, 2024 Author Posted December 6, 2024 Cheers. Its then getting that info to a centralised spreadsheet that's gonna be the next tricky bit.
