Rascal Posted October 11, 2013 Posted October 11, 2013 A user has a folder on his homeshare called 2. Schoolbrede thema's Don't mind the language, it's dutch When the user connects to the homeshare through My Files, this folder is not visible. After renaming the folder (in windows explorer), the results are as follows: 2. Schoolbrede themas visible 2 Schoolbrede thema's visible 2. Schoolbrede thema's not visible The same issue with filenames, so it has to be a combination of . and ' We are using 9.5.831.2140 Somebody else having the same issue? Solution?
Rascal Posted November 12, 2013 Author Posted November 12, 2013 Anyone? I have included 2 screenshots to show the problem. One is a screenshot within Windows Explorer, showing 3 folders. The other one is HAP-my files, showing the same folder. As you can see 1 folder is missing... Am I the only one having this problem?
