  • entry
    1
  • comment
    1
    162
HELP! Projector flickering/Colors changing!
Epson Powerlite 460 projector that turns colors. Manual says to check connections. That didn't solve it. Have a student who is prone to seizures and can't use it. It flickers when the color changes. Projector was not on long before it started to flicker colors so I don't think it's a heat thing.
1 Comment
beaches511
we had something similar happen with a batch of NEC 100 projectors. Changed lamps, connectors, everything we could think of. It was ultimately a fault with the projector so had to be returned for repair and replacement. Might be worth contacting the supplier?
