acer 5720e black screen problem help or advice please .
hi guys im new to this site,hope ive opened a new post here ? and am not posting out of place.
having read a few related posts here ,i have tried out a few of the answers provided on this subject here and still no go .![]()
have got an acer 5720e which had a light wine spill on the keyboard ,and was quickly dried out ![]()
it was immediately ,switched off and unplugged etc, it had a couple of days on the boiler open and drying out .
had the back off etc and took out the ram and what i could .
it reboots as a brick ...black screen ,some fan movement one hard drive flash and remains powered on till you kill it by holding down the start key .ive swapped cd rom drive ,{green light stays on all the time },removed cd rom drives whilst attempting to boot from usb and even removed the hdd hoping to use usb .still no show .
ive tried using fn+esc method : plug power in and hold down fn esc keys method on formatted fat usb drive .
also bootable cd rom copying the fd file supplied by acer bios update 45 as described on this blog ,nothing
should i try and get a new bios chip off ebay ive seen them for sale?,or am i wasting money and effort ,
i can solder etc and do the fix myself .
ive checked hdd on my other pc alls good .
i can only assume it must be bios or worse .
any advice help would be great.
if it needs a new mobo ,is it worth fixing . cheers !
