    4
    2
    353
PowerPoint Automation part I
After a hectic couple of weeks, I've finally started looking at the file management thing again. I think this should handle the actual moving and renaming of the file themselves (as yet untested, I plan to test it tonight when I get home). The updating of links in PowerPoint files is currently on hold until either I find a reliable fix for the PowerShell localization problem with Office, or I get around to using PowerShell 2 instead. I'm assuming its fixed there.
For anyone interested in the code, its stuck in below.
function Move-Files ($OldPath, $NewPath, $Overwrite)
$OldPath = $OldPath.TrimEnd('\') + '\'
$Filenames = Get-ChildItem $OldPath -Recurse -Include "*.ppt*"
foreach ($OldFile in $Filenames)
 $Keywords = $OldFile.Split(".")
 $Limit = $Keywords.Count() - 3
 $Buildpath = $Path
 $NewFile = $OldFile
 foreach ($Keyword in $Keywords)
  if ($Count -le $Limit)
   $Buildpath = $Buildpath + ($Keyword) + '\'
   $NewFile = $NewFile -replace "$Keyword."
   if (!(Test-Path $Buildpath))
    New-Item $Buildpath -ItemType Directory
   $Count ++
  $OldFile = $Path + $OldFile
  $NewFile = $Buildpath + $NewFile
  if (!(Test-Path $NewFile))
   Copy-Item -Path $OldFile -Destination $NewFile
  else
   if (!$Overwrite)
    Write-Host -Object "$NewFile already exists - skipping" -ForegroundColor Red -BackgroundColor Black
   else
    Copy-Item -Path $OldFile -Destination $NewFile -Confirm
Edited by jamesb
