Sophos console problems Entry posted by lukang June 10, 2009 153 views Share https://www.edugeek.net/blogs/entry/153-sophos-console-problems/ More sharing options... Subscribe yep and even after restarting - like the OP said - the warnings still show in the Console If you change the ext at the end of this file from a .txt to a .bat and run it on the console server it will clear out old errors.
1 Comment
