    3
  • comment
    1
    553
SCCM Stuck on PXE preparing for network
Hi all,
would like some help please. I have SCCM with PXE boot and WDS. I am trying to image a laptop it PXE ok, it starts the Endpoint configuration manager and says preparing network to start. But it does nothing after that it does not show no Task Sequences at all. Please can you advise on this for me please.
Thank you.
1 Comment
mikemcsharry
Hi
I don't work with schools at moment (so am available!!) and don't have access to machine to check for you.
Check on the config manager box - are all services running? Check Windows Deployment Services and if necessary re-start it.
Also, check if the server is 'pending restart after patches' that can be a pain
