    60
    63
    1,124
When your teachers create their own class teams
How to add the pupils to existing empty teams with powershell
req: a sims report with the columns classcode, admission number, admission number in the office field of 365 accounts, class code in the team name of the format #:classcode#
#get useraccounts, drop in file
get-msoluser -all | where-object {$_.office} | Select-Object Userprincipalname,office | export-csv -path msoluser.csv -NoTypeInformation
#add useraccounts to lookup table
write-output "Adding pupils to lookup"
$xpupils = @{}
import-csv msoluser.csv | foreach {
   $xpupils.add($_.office,$_.userprincipalname)
#fetch teams
write-output "Fetching teams"
$xteams = get-team | Select-Object groupid,displayname
#process teams
write-output "processing teams"
foreach ($xteam in $xteams)
   $xgroupid = $xteam.groupid
   $xname = $xteam.displayname
   $xListofCodes = [regex]::match($xname,'#.*)#').Groups[1].Value
   if ($xListofCodes.length -gt 3){
       $xCodeArray = $xListofCodes -split ","
       Write-Output $xteam.groupid
       foreach ($xcode in $xCodeArray) {
               Write-Output $xcode
               #Write-Output $xcode
               #make an array of admission numbers that are assigned to this code
               $xclassarray = @()
               import-csv studentclasses.csv | foreach {
                   #check row classcode matches $xcode
                   if ($_.class -eq $xcode) {
                           #add to array
                           $xclassarray += $xpupils[$_.adno]
           #printarray
           foreach ($ad in $xclassarray) {
                   Write-Output $ad
                   #add to team.
                   Add-TeamUser -GroupID $xgroupid -user $ad
Edited by browolf
