    7
    7
    455
OLD - Boot and Logon wallpaper generation using PowerShell.
Latest version of scripts and information can be found on: https://github.com/DJ-1701/GenerateWallpaper
Old information below...
The following details shows you how to create Boot and Logon wallpapers using existing wallpaper and adding an overlay of text which can display your school name, computer name, etc via PowerShell scripts which I have created and you may reuse, edit, butcher, etc. :).
Examples of this style can be found below:
Boot
Logon
For this exercise we are going to use some pre-created wallpapers for Windows 10 in 19x6 (aka Widescreen) and 4x3 (aka Standard) resolutions, which can be downloaded here.
Extract the zip file to a folder with the School’s name. So, the folder path to both directories should be:
SchoolName\Wallpaper\4x3
SchoolName\Wallpaper\19x6
Feel free to have a look at the images in the folder, and delete and add images as you see fit. There are around 280MB worth of images, so you may want to delete some if your machines don’t have much space. After you have finished, copy the SchoolName directory to your Domain Controller’s netlogon share (i.e. \\FQDN\netlogon - where FQDN is the fully qualified domain name for your active directory domain).
Next we are going to take a look at the basic code.
Update Wallpaper
# Wallpaper folder source.
$Domain = (Get-WmiObject -Class Win32_ComputerSystem).Domain
$NetworkSource = "\\$Domain\NetLogon\SchoolName\Wallpaper"
$LocalSource = "$Env:ProgramFiles\SchoolName\Wallpaper"
# Custom wallpaper override file.
# Note: Value used to prevent deletion of local file when mirroring.
$Override = "$LocalSource\Override.jpg"
# Path to robocopy command.
$WinDir = (Get-Childitem env:WinDir).Value
$Robocopy = "$WinDir\System32\Robocopy.exe"
If (!(Test-Path($Robocopy)))
   Write-Host "$Robocopy does not exist."
   Exit
If (!(Test-Path($NetworkSource)))
   Write-Host "$NetworkSource does not exist."
   Exit
If (!(Test-Path($LocalSource)))
     New-Item -ItemType directory -Path $LocalSource
# Update local wallpapers.
&$Robocopy "$NetworkSource" "$LocalSource" /MIR /XF "$Override" /R:1 /W:1 /NP
Copy and paste the code above into PowerShell ISE, so you can create a PS1 file, and test the code if you so wish.
Please note:
  • PowerShell ISE needs to be run as an Administrator for certain aspects of the script to work.
  • Rename SchoolName in the script to the actual School Name (i.e. the folder you just copied to you Domain Controller’s netlogon share).
Save the script as \\FQDN\netlogon\Update Wallpaper.ps1 (where FQDN is the fully qualified domain name for your active directory domain).
When running the script as an Administrator, you should find this will copy the SchoolName folder down from the netlogon share to the C:\Program Files folder on the local computer.
Boot Info
# Text for the wallpaper.
$TextLabel = "School Address Here`r`nTelephone: Telephone Number Here`r`nComputer Name: "+((Get-Childitem env:ComputerName).Value)
$TextSizePoint = 18
# Text box colour.
$BoxRed = 22
$BoxGreen = 176
$BoxBlue = 221
# Text colour.
$TextRed = 255
$TextGreen = 255
$TextBlue = 255
# Wallpaper source folder.
# Completed wallpaper destination location.
$SystemBackgroundDir = "$WinDir\system32\oobe\info\backgrounds"
$DestinationFile = "$SystemBackgroundDir\backgroundDefault.jpg"
   Write-Host "$LocalSource does not exist."
   Exit
If (!(Test-Path("$SystemBackgroundDir")))
  New-Item -ItemType directory -Path "$SystemBackgroundDir"
# Find current screen resolution.
# Note: Interrogating [system.Windows.Forms.Screen] at boot returns false 1024x768.
#       Therefore, a separate login script stores this data on user login to a registry key.
#       After which the PC can check this key. If data does not exist, it will use
#       recommended supported resolution data. If this fails, it will default to 1024x768.
$RegistryPath = "HKLM:\Software\MachineData"
If ((Test-Path $RegistryPath))
   If (((Get-ItemProperty -Path $RegistryPath).Horizontal -ne $null) -and ((Get-ItemProperty -Path $RegistryPath).Vertical -ne $null))
       $Horizontal = [int]((Get-ItemProperty -Path $RegistryPath).Horizontal)
       $Vertical = [int]((Get-ItemProperty -Path $RegistryPath).Vertical)
If ($Horizontal -eq $null) {$Horizontal = [int]((Get-WmiObject -Class Win32_VideoController).CurrentHorizontalResolution)}
If ($Vertical -eq $null) {$Vertical = [int]((Get-WmiObject -Class Win32_VideoController).CurrentVerticalResolution)}
If ($Horizontal -eq $null) {$Horizontal = [int]"1024"}
If ($Vertical -eq $null) {$Vertical = [int]"768"}
If ($Horizontal/$Vertical -le 1.4)
   $Ratio = "4x3"
Else
   $Ratio = "16x9"
$SourceDir = "$LocalSource\$Ratio"
If (!(Test-Path($SourceDir)))
   Write-Host "$SourceDir does not exist."
   Exit
# Select a random file as the source wallpaper.
$Files = (dir -Path $SourceDir\* -Recurse).FullName
$SourceFile = $Files | Get-Random
# If override wallpaper exists, change source file.
If ((Test-Path($Override)))
   $SourceFile = $Override
# If no source file exists, exit.
If (!(Test-Path($SourceFile)))
   Write-Host "$SourceFile does not exist."
   Exit
If ($? -eq $false)
   Write-Host "Null Source File."
   Exit
# Enable the creation of images.
Add-Type -AssemblyName System.Drawing
# Select a font, size and style.
$TextSizePixels=$TextSizePoint/0.75
$Font = New-Object System.Drawing.Font("Arial",$TextSizePixels,[Drawing.FontStyle]'Bold',"Pixel")
# Get source image from source file.
$SourceImage = [system.Drawing.Image]::FromFile($SourceFile)
# Create a new bitmap at the primary monitor resolution to construct an image.
$Bitmap = New-Object System.Drawing.Bitmap($Horizontal,$Vertical)
# Create image for editing.
$Image = [system.Drawing.Graphics]::FromImage($Bitmap)
# Ensure the image is clear.
$Image.Clear([system.Drawing.Color]::FromArgb(255,255,255,255))
# Set the ARGB values required for the text and text box.
$TextARGB = [system.Drawing.Color]::FromArgb(255,$TextRed,$TextGreen,$TextBlue)
$BoxARGB = [system.Drawing.Color]::FromArgb(255,$BoxRed,$BoxGreen,$BoxBlue)
# Set area for text placement.
$Rectangle = [system.Drawing.RectangleF]::FromLTRB(0, 0, $Horizontal, $Vertical)
# Set alignment format for the font.
$FormatFont = [system.Drawing.StringFormat]::GenericDefault
$FormatFont.Alignment = [system.Drawing.StringAlignment]::Center
$FormatFont.LineAlignment = [system.Drawing.StringAlignment]::Near
# Get text path Layout to work out text box co-ordinates.
$TextPath = New-Object System.Drawing.Drawing2D.GraphicsPath
$TextPath.AddString($TextLabel,$Font.FontFamily,$Font.Style,$Font.Size,$Rectangle,$FormatFont)
# Get co-ordinates of beginning and end of text.
$StartX = $Horizontal
$StartY = $Vertical
$EndX = 0
$EndY = 0
ForEach ($PathPointRow in $TextPath.PathPoints)
   If ($PathPointRow.X -le $StartX){$StartX = $PathPointRow.X}
   If ($PathPointRow.Y -le $StartY){$StartY = $PathPointRow.Y}
   If ($PathPointRow.X -gt $EndX){$EndX = $PathPointRow.X}
   If ($PathPointRow.Y -gt $EndY){$EndY = $PathPointRow.Y}
$EndX = $EndX - $StartX
$EndY = $EndY - $StartY
# Set up the brush colours for drawing text box and text string.
$BoxBrushColour = New-Object Drawing.SolidBrush $BoxARGB
$TextBrushColour = New-Object Drawing.SolidBrush $TextARGB
# Draw image.
$Image.DrawImage($SourceImage,0,0, $Horizontal, $Vertical)
# Draw box.
$Image.FillRectangle($BoxBrushColour,$StartX,$StartY,$EndX,$EndY)
# Draw text.
$Image.DrawString($TextLabel,$Font,$TextBrushColour,$Rectangle,$FormatFont)
# Find last boot time to display on Wallpaper.
$TextLabel = "Last Boot: "+((Get-Date).DateTime)
$TextSizePoint = 10
$Font = New-Object System.Drawing.Font("Arial",$TextSizePoint,[Drawing.FontStyle]'Bold',"Pixel")
$FormatFont.Alignment = [system.Drawing.StringAlignment]::Near
$FormatFont.LineAlignment = [system.Drawing.StringAlignment]::Far
# Get co-ordinates of beginning and end of text, and add padding for text box.
$StartY = $Vertical
$EndX = 0
$EndY = 0
$EndX = $EndX - $StartX + 15
$EndY = $EndY - $StartY + 15
$StartY = $StartY - 5
$StartX = $StartX - 5
# Draw box.
# Draw text.
# Save edited bitmap to file.
$Bitmap.Save($DestinationFile,[system.Drawing.Imaging.ImageFormat]::Jpeg)
# Clean up and remove objects.
$SourceImage.Dispose()
$Bitmap.Dispose()
$Image.Dispose()
$SourceDestinationFile
# Open saved file.
#Invoke-Item $DestinationFile
Please note:
  • Edit the section after '$TextLabel = "' to change the text which is saved on the wallpaper.
Save the script as \\FQDN\netlogon\SchoolName\Wallpaper\Boot Info.ps1 (where FQDN is the fully qualified domain name for your active directory domain).
When running the script as an Administrator, you should find this will grab a random file from the correct screen ratio folder (or nearest, if you have a non-standard/old widescreen) generate the text to overlay (so in this case School Address, Telephone Number and Computer Name in the top centre, and the Boot Time in the bottom left) and save the file to C:\Windows\System32\oobe\info\backgrounds\backgroundDefault.jpg.
The reason we are using this location by default is because it is also the standard location Windows 7 looked to for a corporate wallpaper, the path can be changed on Windows 10 if you wish to place it elsewhere.
Please note that the wallpaper will not change until we update group policy to force this new file, but you can view the output in the file mentioned above.
Logon Info
$TextLabel = "School Address Here`r`n`r`nUser Name: "+($env:USERNAME)+"`r`nComputer Name: "+($env:COMPUTERNAME)+"`r`nModel: "+((Get-WmiObject Win32_ComputerSystem).Model)+"`r`nSerial Number: "+((Get-WmiObject Win32_ComputerSystemProduct).IdentifyingNumber)
$TextSizePoint = 12
# Text box colour.
$BoxRed = 0
$BoxGreen = 125
$BoxBlue = 255
# Text colour.
$TextRed = 255
$TextGreen = 255
$TextBlue = 255
$DestinationFile = "$env:temp\LogonInfo.jpg"
# Clear theme cache files.
Remove-Item -Path "$($env:APPDATA)\Microsoft\Windows\Themes\*" -Recurse -Force -ErrorAction SilentlyContinue
# Ensure image is set to Stretch to screen resolution and not tile.
Set-ItemProperty -Path 'HKCU:\Control Panel\Desktop' -Name WallpaperStyle -Value "2" -Force
Set-ItemProperty -Path 'HKCU:\Control Panel\Desktop' -Name TileWallpaper -Value "0" -Force
   Exit
#       Therefore, this login script stores the data on user login to a registry key.
#       After which the boot script can check this key. If data does not exist, it will use
[void] [system.Reflection.Assembly]::LoadWithPartialName("System.Windows.Forms")
$Horizontal = [int]([system.Windows.Forms.Screen]::AllScreens[0]).Bounds.Width
$Vertical = [int]([system.Windows.Forms.Screen]::AllScreens[0]).Bounds.Height
If (!(Test-Path $RegistryPath)) {New-Item -Path $RegistryPath -Force}
New-ItemProperty -Path $RegistryPath -Name "Horizontal" -Value $Horizontal -PropertyType DWORD -Force
New-ItemProperty -Path $RegistryPath -Name "Vertical" -Value $Vertical -PropertyType DWORD -Force
   $Ratio = "4x3"
Else
   $Ratio = "16x9"
   Exit
# If username does not start with Student, look to see if the user has a personal wallpaper they wish to use instead.
If (!(($env:USERNAME) -like "Student*"))
   If (Test-Path("$env:userprofile\Documents\Wallpaper\Wallpaper.jpg"))
       $SourceFile = "$env:userprofile\Documents\Wallpaper\Wallpaper.jpg"
   ElseIf (Test-Path("$env:homeshare\Wallpaper\Wallpaper.jpg"))
       $SourceFile = "$env:homeshare\Wallpaper\Wallpaper.jpg"
   Exit
If ($? -eq $false)
   Exit
# Use .Net Framework to create a class to update and refresh the Wallpaper.
Add-Type @”
   using System;
   using System.Runtime.InteropServices;
   using Microsoft.Win32;
   namespace Wallpaper
       public class UpdateImage
           [DllImport("user32.dll", SetLastError = true, CharSet = CharSet.Auto)]
           private static extern int SystemParametersInfo (int uAction, int uParam, string lpvParam, int fuWinIni);
           public static void Refresh(string path)
               SystemParametersInfo( 20, 0, path, 0x01 | 0x02 );
$FormatFont.Alignment = [system.Drawing.StringAlignment]::Far
$StartY = $Vertical
$EndX = 0
$EndY = 0
$EndX = $EndX - $StartX + 5
$EndY = $EndY - $StartY + 10
$StartX = $StartX
# Draw image.
# Draw box.
# Draw text.
$Bitmap.Dispose()
$Image.Dispose()
# Open saved file.
# Update wallpaper.
[Wallpaper.UpdateImage]::Refresh($DestinationFile)
Please note:
  • Edit the section after '$TextLabel ="' to change the text which is saved on the wallpaper.
Save the script as \\FQDN\netlogon\Logon Info.ps1 (where FQDN is the fully qualified domain name for your active directory domain).
When running the script as an Administrator, you should find this will grab a random file from the correct screen ratio folder (or nearest, if you have a non-standard/old widescreen) generate the text to overlay (so in this case School Address, User Name, Computer Name, Model and Serial Number in the top right) and save the file to the user’s temporary folder %Temp%\LogonInfo.jpg
On a typical computer this would be: C:\Users\%Username%\AppData\Local\Temp\LogonInfo.jpg[/Code]
This script will also grab the most accurate data of the screens current resolution and store it in the registry location HKEY_LOCAL_MACHINE\Software\MachineData, which can then also be used by the Boot Info script.
Please note that the wallpaper will not change until we update group policy to force this new file, but you can view the output in the folder mentioned above.
[b]Group Policy
[/b]The group policy settings to enforce these wallpapers are as follows.
For the logon wallpaper, this will affect User Policy, so either create a new policy for the users, or edit an existing one and:
[/size]
  1. [size=1]Go to User Configuration -> Policies -> Windows Settings -> Scripts (Logon/Logoff) -> Logon, and then click on the PowerShell Scripts tab, press Add, and for the script name type in the full path you stored the logon script (i.e. \\FQDN\netlogon\Logon Info.ps1).[/size]
  2. [size=1]Go to User Configuration -> Policies -> Administrative Templates -> Desktop -> Desktop -> Desktop Wallpaper, and enable the policy, specifying the location as %temp%\LogonInfo.jpg and setting the wallpaper style to Stretch.[/size]
[size=1]
For the boot wallpaper, this will affect Computer Policy, so either create a new policy for the machines, or edit an existing one and:
[/size]
  1. [size=1]Go to User Configuration -> Policies -> Windows Settings -> Scripts (Logon/Logoff) -> Logon, and then click on the PowerShell Scripts tab, press Add, and for the script name type in the full path you stored the Update Wallpapers script (i.e. \\FQDN\netlogon\Update Wallpapers.ps1), next add another script name again, this time type the full path for the boot script (i.e. C:\Program Files\SchoolName\Wallpaper\Boot Info.ps1).[/size]
  2. [size=1]Go to User Configuration -> Policies -> Administrative Templates -> Control Panel -> Personalization -> Force a specific default lock screen and logon image, and enable the policy, specifying the location as:
    [Code]C:\Windows\System32\oobe\info\backgrounds\backgroundDefault.jpg[/Code]
    [/size]
Edited by DJ-1701
2 Comments
philellis
Hi DJ-1701
This seems to work perfectly for what we're wanting to achieve however are unable to run the PowerShell script with admin credentials on login which is why I think it's not replicating for standard users. Add to that Microsoft 'patching' group policy preferences to run as a different user this has become a bit of an issue. Do you have any advice /pointers?
Cheers
DJ-1701
Hi Philellis,
If the logon script can't/doesn't run as an administrator the file will still be generated, the only thing this would break is storing the resolution in the HKEY_LOCAL_MACHINE\Software\MachineData registry key. A way around that would be to set the machine GPO to create the key in Group Policy Preference, and after that in Policies\Windows Settings\Security Settings\Registry create add the key and allow access to the Authenticated Users to write to this key so the current resolution can be stored there.
Hope this helps,
DJ
