Results 1 to 3 of 3
Mac Thread, Remote Desktop Connection problem in Technical; Hi All, We currently have remote access through RDWeb running on Windows Server 2008R2. I can connect inside the network ...
    The_Oracle's Avatar
    Jul 2008
    Dorset
    1
    13
    Hi All,
    I can connect inside the network using the Microsoft RDC app for OS X but when I try and connect from outside the network I get a message saying "Connection reset by peer".
    I'm new at OS X so am just finding my way round things.
    However I did setup the Heads MacBook Air using iTap last year and that works fine.
    That laptop has not been upgraded to Mavericks, and iTap is no longer available so I don't know if the problem is Mavericks or Microsoft's version of iTap.
    Can anyone point me in the right direction?
    zag
    zag is offline
    zag's Avatar
    Mar 2007
    969
    12
    95
    You dont need to use RDweb, just use a normal Remote Desktop connection for the app on Mac.
    The_Oracle's Avatar
    Jul 2008
    Dorset
    1
    13
    Thanks Zag, unfortunately I get the same message.
    I'm using the Microsoft Remote Desktop app to connect to servername.internaldomain.local through a gateway of remote.externaldomain.com. If I connect from inside the network (so not through the gateway) everything is fine, but once I try going through the gateway I get the error message.
    Works fine on both my iPad and my android phone.
    There must be an event log somewhere - nothing like learning on the job!
  1. Remote Desktop connection to server problem
    By randle in forum Windows
    Last Post: 16th September 2013, 11:29 PM
  2. Remote Desktop Connection to Server.
    By jmair in forum Windows
    Last Post: 29th October 2008, 09:09 PM
  3. Remote Desktop Connection irritation
    By SpuffMonkey in forum Windows
    Last Post: 21st March 2008, 01:50 AM
  4. Remote Desktop Connection Problem
    By FN-GM in forum *nix
    Last Post: 21st October 2007, 04:11 PM
  5. isa server and remote desktop connection
    By russdev in forum Wireless Networks
    Last Post: 16th November 2005, 10:07 PM
