Hi. Does anyone have a copy of a repair guide/service manual for the SP A10 please? I found the link to the Toshiba website but get 403 Forbidden :(
Printable View
Be a real Tech - Take it to bits blind! :twisted:
Here's a site I use if I need to look for a service manual, don't know if it will be there or not.
Service manuals
If it's not there then I agree with simongrahamuk, take it to bits and put it back together when your finished, toshiba's are quite easy to do that with.
I have just had a look on the Toshiba UK protected website (I am Tosh certified) and they don't have an electronic version of the service manual for either the Satellite or Satellite Pro A10. As has been mentioned previously, the A10's are very easy to work on, nothing to awkward at all. What are you trying to achieve? Maybe I can help you through a specific task?
if thats the case y when i chage hard drives it charges whilst the computer is on?
