Where can I get a power distribution unit?
I realised the other day that our rackmount UPS (BlackBox ServSwitch UPS) can actually handle a lot more than the 2 switches that are plugged into it
However there are only 2 outputs, so Im assuming I need a PDU to increase this?
Problem is the outputs are standard C14 connectors (ie kettle leads) while all the PDU's seem to have C19 I think
Anyone recommend one for under £100?
Re: Where can I get a power distribution unit?
According to APC, you can get C14->C19 cables, so it shouldn't be too difficult to get hold of the right cable and/or adapter you need.
Buy a normal pdu and change the plug for an iec inlet one? APC give you one with their ups's
Or:
http://www.tofftech.co.uk/go/product_5783_APC+Power+Cord+(IEC+320+C14+to+UK+Rec eptacle).html
