Results 1 to 12 of 12
Hardware Thread, Power problems? in Technical; This is a bit of a strange one... One of our classroom computers is having intermitten power problems. Sometimes it ...
    X-13's Avatar
    Jan 2011
    /dev/null
    508
    19
    700
    Power problems?
    Sometimes it won't boot, sometimes it will.
    I was just in there looking at why it was on but still had a black screen [power button on the screen was flashing. Signal, but no image.]
    I turned the computer off, then it refused to switch back on. This isn't the first time it's happened.
    I took it away to have a proper look at it, and it seems it takes around 5 minutes or so for the computer to charge up...
    This is the only way I can think to explain it.
    The motherboard light starts off dim, then gets stronger. When the power button is pressed, the light dims further until a certain point, where it stays stable.
    After a few mintues, the fans will kick in when the power button is pressed, but it'll die. Then turn on without having anything touched.
    TBH, I'm thinking this is a PSU problem. Or the start of one at least.
    Any ideas?
    Jan 2012
    1
    5
    We once had room full of shuttle computers which did this but we never got to the bottom of the problem.
    Possibly a Power Supply issue.
  3. Thanks to Kenny_G from:
    X-13 (26th March 2012)
  4. #3
    X-13's Avatar
    Jan 2011
    /dev/null
    508
    19
    700
    Cheers, Kenny G. [You're not a jazz saxophonist, are you?]
  5. #4
    Sep 2008
    310
    107
    Viglen? - We had almost the very same thing happen and it seemed to be a dodgy PSU with a batch. Replacing the power seemed to sort the problem.
  6. Thanks to penfold from:
  7. #5
    X-13's Avatar
    Jan 2011
    /dev/null
    508
    19
    700
    Quote Originally Posted by penfold View Post
    RM.
    And they're JUST out of warrenty. Usually, I'd just drop RM a call and they'd send someone out...
    Also, this is the... 3rd [4th?] with EXACTLY the same problem. All over the school, all computers bought at DIFFERENT times.
    All used to varying degrees. [Some hardly used, some used to excess.]
  8. #6
    Michael's Avatar
    Dec 2005
    Birmingham
    232
    328
    Sounds like a cold boot or PSU problem to me. Replacing the PSU should be fairly straight forward, but failing that, it could well be the motherboard on its way out.
  9. Thanks to Michael from:
  10. #7
    X-13's Avatar
    Jan 2011
    /dev/null
    508
    19
    700
    Quote Originally Posted by Michael View Post
    ah, [censored]
    Seeing as the older ones that have died are about 5 years old, I think I'm going to have to suggest replacing them instead of repairing.
  11. #8
    rich_tech's Avatar
    Mar 2011
    Wales
    114
    60
    I had a similar problem a while back with my old Antec Trupower PSU in my home machine, the voltage wouldnt get high enough at times to allow it to boot up the machine, one of the rails in the device would hover about 10v and I had to repeatedly power it off and on on the PSU switch until it got a high enough voltage to start up, I replaced it a while later.
    What I would recommend is getting a power supply tester, I got mine cheap off ebay, its worth the world with problems like this, as you can diagnose problems quickly and easily.
    I have one like this - PC LCD 20/24 Pin PSU SATA HD ATX BTX ITX Power Supply Tester Test Power Voltage | eBay - I would get one that shows voltage levels on it over the other type with just LEDs, its a bit more informative as to what is going on with the PSU
  12. 2 Thanks to rich_tech:
    jedmondson (26th March 2012), X-13 (26th March 2012)
  13. #9
    X-13's Avatar
    Jan 2011
    /dev/null
    508
    19
    700
    Thanks, Rich.
    I was looking into getting one before all this started anyway. At least I have a good reason now.
  14. #10
    AButters's Avatar
    Feb 2012
    Wales
    103
    36
    Pop the lid and see if the motherboard has any capactors that are either leaking or have bulged tops:
    Leaking:
    Bulged:
    China seriously screwed up millions of caps about 6-7 years ago and many manufacturers ended up having PCs/motherboards fail because of it.
    We had 65 PCs die within 2 years (when they were 4 years old).
    If it's not the above then it probably is the power supply as suggested by other good people above
  15. Thanks to AButters from:
  16. #11
    X-13's Avatar
    Jan 2011
    /dev/null
    508
    19
    700
    @AButters That was the second thing I did.
    The first was check the power cable worked.
  17. #12
    Mar 2008
    Bromley
    15
    16
    Quote Originally Posted by rich_tech View Post
    Just brought one myself as I have had 2 computers come to me with dodgy power supply.
  1. Windows 7 Power problems
    By Stuart_C in forum Windows 7
    Last Post: 4th October 2011, 03:31 PM
  2. Replies: 1
    Last Post: 20th January 2009, 05:21 PM
  3. [Sold/Traded] Laptop (with power problem)
    By enjay in forum Classified Adverts
    Last Post: 13th March 2008, 09:26 AM
  4. Acer Laptop strange power problems!
    By maniac in forum Hardware
    Last Post: 11th January 2008, 01:24 PM
  5. Viglan Pc Power Problems
    By marks20 in forum Hardware
    Last Post: 24th July 2007, 09:12 AM
