Results 1 to 6 of 6
Hardware Thread, Fixing a cabinet to a brick wall in Technical; I have a small (6Ux550mm) wiring cabinet to fix to a brick wall. It will contain one switch and one ...
    Feb 2010
    36
    10
    Question Fixing a cabinet to a brick wall
    I have a small (6Ux550mm) wiring cabinet to fix to a brick wall. It will contain one switch and one patch bay - nothing heavy like servers or batteries - and will be well out of reach of small people.
    The cabinet has four holes on the back face. I was planning to use four wall bolts, rather like these. Does that sound reasonable?
    Jan 2009
    United Kingdom
    22
    13
    You can, however I have found they are particularly difficult to fit quite often, and getting them into the hole often makes them too loose, and they then 'spin', which means you can never lock them up!
    Depending on whether the face is smooth enough, from experience, we now use very big decent wall plugs, with a lip (to stop them pushing into the wall) and coarse 'coach' screws with a hex head. They work really well, and I have done a few cabs now this way with much success. The hex head also makes it easy to use a ratchet spanner inside the cab as well. We use these rawlplugs, they really are excellent.
    Hope this helps
    Mark
  3. Thanks to _techie_ from:
    will_ (29th October 2011)
  4. #3
    Mar 2008
    Bromley
    15
    17
    how about using some shelving brackets bellow as well?
  5. Thanks to jedmondson from:
  6. #4
    plexer's Avatar
    Dec 2005
    Norfolk
    681
    426
    Quote Originally Posted by will_ View Post
    PM your address and I will send you 4 bolts, fischer rawlplugs and washers to fit this.
  7. Thanks to plexer from:
  8. #5
    Oct 2008
    Lincolnshire
    13
    68
    That is all we used for the cabinets we put up Will, got a pack of 8 I think in screw fix for a few quit. We often have 3 Cisco switches, a router, firewall plus all the patching and power in a bigger 12U cab on the same bolts.
  9. Thanks to MatthewL from:
  10. #6
    Feb 2010
    36
    10
    Thank you all for your advice.
    Plexer: PM sent.
  1. server cabinet / wall box wanted
    By FN-GM in forum General Chat
    Last Post: 11th September 2007, 03:11 PM
  2. Fix or disable XP Pro "logon to box" on 2003 Server network
    By tazz in forum How do you do....it?
    Last Post: 29th August 2007, 03:15 PM
  3. Replies: 5
    Last Post: 2nd July 2007, 08:20 AM
  4. I need a favour - screws to fix fans into cases!
    By indiegirl in forum Hardware
    Last Post: 9th June 2006, 10:08 AM
  5. Fixing things to walls...
    By indie in forum Hardware
    Last Post: 3rd December 2005, 03:04 PM
