Results 1 to 5 of 5
Hardware Thread, Realtek HD Audio output not an option with M-Audio Delta 1010LT Multi in Technical; Having setup our 5 new music machines during the summer holiday 2 of them will not output audio. The machines ...
    bondbill2k2's Avatar
    Jan 2011
    West Midlands
    81
    2
    42
    Having setup our 5 new music machines during the summer holiday 2 of them will not output audio. The machines have a realtek on baord sound card with an M-Audio Delta 1010LT for input of keyboards and other instruments. On the two machines which arnt working the realtek HD device isn't reconised but the drivers are installed. Under windows volume controls > options > properties the only options for mixer devices are the M-Audio equiptment, those which do work have both the M-Audio equiptment and the Realtek HD output.
    Ive tryed removing the drivers for the M-Audio and Realtek then just install the realtek drivers but still the same problem...
    SYNACK's Avatar
    Oct 2007
    882
    11
    784
    Have you checked in the bios to make sure the advanced features of the card are enabled. Some boards had a setting to disable it so that backward rubbish like XP could handle it without all the additional drivers.
  3. Thanks to SYNACK from:
    bondbill2k2 (8th September 2011)
  4. #3
    Oct 2006
    184
    149
    Just use the Maudio outputs, they are going to be a gazillian times better than the realtek ones?
  5. #4
    Jan 2011
    West Midlands
    81
    2
    42
    Quote Originally Posted by j17sparky View Post
    The M-Audio has no 3.5mm jack and the students often used headphones in the front ports. Thanks SYNACK I didnt think to look at bios level and you were right it was disabled for some reason -_-
  6. #5
    Oct 2006
    184
    149
    Quote Originally Posted by bondbill2k2 View Post
    Aye but the music software will be using ASIO drivers which the realtek doesn't have so... get an adaptor. It's sorted anyway but have a look at your music softwares settings as if it is using the realtek card at all it is set up incorrectly - unless you are using ASIO4ALL which imo is a bit daft if you've payed all that money for a proper soundcard with native ASIO drivers.
    http://en.wikipedia.org/wiki/Audio_Stream_Input/Output
  1. Replies: 14
    Last Post: 11th June 2013, 11:42 AM
  2. Front Panel Support - Realtek HD Audio
    By Hightower in forum AV and Multimedia Related
    Last Post: 6th September 2011, 11:16 AM
  3. Realtek HD Audio
    By Quackers in forum Hardware
    Last Post: 11th February 2009, 02:38 PM
  4. RealTek HD Audio Problem
    By wesleyw in forum Windows
    Last Post: 16th January 2008, 07:00 PM
  5. Can only do an upgrade with Schools Agreement?
    By sidewinder in forum Windows Vista
    Last Post: 20th March 2007, 10:16 AM
