Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Hardware Thread, USB Solenoid lock controller for laptop charging cabinet in Technical; How about just getting a parallel (printer) to USB adaptor cable? Connect each switch to a data pin on the ...
  1. #16
    Oct 2007
    Lincolnshire
    17
    How about just getting a parallel (printer) to USB adaptor cable? Connect each switch to a data pin on the parallel end with a pull-up resistor. Provided the lead is bidirectional you should be able to read the switch status as a bitmap from the USB end.
  2. Thanks to keithu from:
    dhicks (10th August 2011)
  3. #17
    plexer's Avatar
    Dec 2005
    Norfolk
    648
    421
    Which then means having a full blown pc next to it rather than a small network connected aruidno.
  4. Thanks to plexer from:
  5. #18
    dhicks's Avatar
    Aug 2005
    Knightsbridge
    1,240
    235
    Quote Originally Posted by plexer View Post
    No problem, that's my current preferred solution - we have plenty of spare, if rather old, PCs. We can swap out the harddrive for a CF card to save power and I can plug in a touch-screen monitor to be the user interface. I just need a USB device to be permanatly attached to the PC to sense switches being pushed.
  6. #19
    dhicks's Avatar
    Aug 2005
    Knightsbridge
    1,240
    235
    Quote Originally Posted by keithu View Post
    Heck, we've got PCs with parallel ports.
    What's a "pull-up" resistor? Will I need resistors of a specific value? I assume I'll need to find some way of getting the positive pin in the parallel cable to provide power to all six switches - some kind of one-to-six-way cable split?
  7. #20
    plexer's Avatar
    Dec 2005
    Norfolk
    648
    421
  8. Thanks to plexer from:
  9. #21
    plexer's Avatar
    Dec 2005
    Norfolk
    648
    421
  10. Thanks to plexer from:
  11. #22
    dhicks's Avatar
    Aug 2005
    Knightsbridge
    1,240
    235
    Ah ha - many thanks. I've just Googled "pull-up resistor" too and found it's a particular type of resistor - I always thought a resistor was just a resistor before. Parallel ports seem to have 7 inputs, which would seem to be just right in this case, although I might still try an Ardunio as it would allow for future expansion.
  12. #23
    Oct 2007
    Lincolnshire
    17
    Quote Originally Posted by dhicks View Post
    You don't need to provide power to the switches, just connect each one between one of the parallel port data pins and ground. When the switch is closed the data pin is at 0v and will read as a '0'.
    When the switch is open we want the input voltage to rise to 5v and read as a '1'. That's the purpose of the pull-up resistor. Each input pin has a 4.7k resistor between itself and the +5v supply which 'pulls up' the input to 5v when nothing is connected (ie the switch is open). Having said that, your printer port may well have pull-up resistors already so you wouldn't have to bother adding them yourself.
  13. Thanks to keithu from:
  14. #24
    SYNACK's Avatar
    Oct 2007
    868
    11
    772
    Your using one more computer than you need, the Arduno is great and everything but excels at its intended purpose of being a reasonably standalone controller. Adding a bunch of extra logic in the middle is just going to make it more comples. Use something like this instead Amazon.com: Cana Kit 4-Port USB Relay Controller with 6-Channel I/O Interface: Electronics or http://www.pc-control.co.uk/relaybee_info.htm
  15. Thanks to SYNACK from:
  16. #25
    plexer's Avatar
    Dec 2005
    Norfolk
    648
    421
    I knew I'd seen a flyer for a similar but commercial system.
    Diplomat | Laptop Lockers | Lapsafe
  17. Thanks to plexer from:
    dhicks (11th August 2011)
  18. #26
    Mar 2014
    Hello!
    Glenna mentioned in 2009 "Look at what I have used for the Network Kettle - you could use a Web relay (although around $130) which can control up to 4 doors and then just have a web form which once submitted is checked against AD or similar (ldap) which once authenticated you could then run the script to open a solenoid." This is exactly the solution I'm looking for - a lock controlled by AD login. I couldn't find the reference to what was done for the "Network Kettle" but I'd be very interested to find and end-to-end solution for this: a lock, preferably cabinet style (but if I have to I'll but a dead bolt on it!) that is normally locked, releases after a authorized user provides AD authentication.
    Suggestions?
    Thank you!!
  19. #27
    midomidi2013
    Guest
    The arduino would do the sensors/missing logic for you(no need to script this externally) - you would need to poll the arduino for status updates to check against your bookings though.
  1. Idea for laptop manufacturers
    By laserblazer in forum Hardware
    Last Post: 11th August 2011, 11:30 AM
  2. Charging cabinet for MSI U100 Netbook
    By westleya in forum Hardware
    Last Post: 8th July 2009, 09:38 AM
  3. Replies: 42
    Last Post: 20th November 2008, 10:58 AM
  4. USB Pen Drive shuts down laptop
    By Mr_M_Cox in forum Windows
    Last Post: 7th November 2007, 04:30 PM
  5. Recomend someone for laptop repairs
    By ind13 in forum Hardware
    Last Post: 10th November 2006, 11:38 AM
