Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Hardware Thread, Spare parts for HP 3005 Printer in Technical; I've got an HP 3005n which needs a new formatter board - it's sticks on startup with a memory error, ...
    maniac's Avatar
    Feb 2007
    Kent
    209
    144
    I've got an HP 3005n which needs a new formatter board - it's sticks on startup with a memory error, but the main memory is part of the board. It's only 18 months old, but far enough out of warranty for HP to tell me to go away (which is fair enough) and want to charge me lots to fix it (They don't supply the parts to end users )
    So can anyone help me get hold of a formatter board for this printer to I can put it back in use - it'll be a shame to have to scrap it for the sake of a circuit board - the rest of the printer is absolutely fine. Part number is Q7848-60002
    I have googled, which brought up a handful of sellers selling second hand parts, but none of the UK ones I rang actually had it in stock.
    Cheers
    Mike.
    ranj's Avatar
    Feb 2006
    Birmingham
    98
    25
    We have about 4 of these printers in our school and I have to say I have been disappointed with these. We have had the problem you mentioned but it was in warranty, and a 'top bin is full' message on a few others.
    I get the sense this printer is not really designed for an educational environment and have been disappointed with HP.
    I have decided to give Kyocera a try. See how they handle in our environment.
    Advice to schools who have this printer,If you haven't already and within 12 months of purchase 'BUY THE EXTENDED WARRANTY' you'll thank me for it!
    I have a supplier who can always help in these situations,not let me down, I would suggest you give him a try. PM me for his details, not sure if I am allowed to advertise on here.
    flyinghaggis's Avatar
    Jan 2006
    104
    116
    2 of our 6 P3005N's have failed inside a year with this fault. All our P2055DN's ramdonly drop of the network requiring a restart every day to get them working again. See thread below :-
    HP LaserJet P2055DN's going offline and not responding
    The P2015's before that used to randomly loose their IP address settings!
    I'm literally at the point where I'm contemplating never buying another HP printer again because their quality control department appears to have gone completely out to lunch!
    HP Printers these days appear to be absolute junk
    Anyone recommend any alternatives?
    Mar 2006
    2
    18
    We've had a few formatter boards go in our P series printers, it is a problem across the range. Shame really because otherwise (IMO) they are cracking printers.
    A few sources on the 'net reckon this is due to the lead free solder that is used nowadays. People have reported good results from popping the formatter board in a hot oven for around 8 minutes
    I'm going to try it on one a bad 3005 formatter board we have when I get some spare time.
    I found the formatter boards are often close to the price of a new printer so I keep my eyes open on eBay and such for spares. I think the last fully working 3005 printer I got was around £90 and came with a genuine 51X toner!
    If you create a DHCP reservation and pointer for the 2015s you will avoid the problem of lost config(s).
    HTH
    CPLTD's Avatar
    Apr 2008
    Northamptonshire
    1,401
    1
    261
    I would suggest taking a look at the Brother range of printers, we have sold many into the public sector and can say that i havent had anything but good feedback for not only reliability but also consumable costs,
    there are a few great Brother deals on at the min including cash back and 3 year warranties so if you fancy some more info be sure to pm and i'll do what i can to help,
  6. #6
    maniac's Avatar
    Feb 2007
    Kent
    209
    144
    Seems like this is a common problem then. I'm definitely not buying HP any more, after this and a series of other problems I just have little to no confidence in them. I've started looking at Xerox printers, as we have one of these in our staffroom and it's the most reliable printer we have, and well built as well.
    Mike.
  7. #7
    maniac's Avatar
    Feb 2007
    Kent
    209
    144
    Just started googling for this problem, and this thread on another forum HP P3005 Formatter card problems. - fixyourownprinter.com is very interesting reading for anyone with these sorts of problems.
    Mike.
  8. #8
    Jan 2006
    104
    116
    Quote Originally Posted by Big_Dave View Post
    HTH
    We've already done it but cheers for the advice! That's frustrating but at least it's fixable. The dead formatter boards and P2055 NICs dying completely are much more serious issues as at the moment since there's no work around for the former and a dead formatter board means basically buying a new printer.
    All the more frustrating that, from reading this message board and others, they're widespread faults which HP wont acknowledge and are unable to fix
    Not sure about Brother as we've bought their printers previously but moved away from them as we weren't keen on the separate toner/drum setup. In my experience it wastes a lot of time troubleshooting as you never know whether or not it's the toner/drum that's faulty and often staff throw away a perfectly good toner cart before the drum is replaced negating any cost saving from having separate drums/toner. Their drivers have proved to be a bit hit and miss when it comes to correctly rendering some types of print jobs sent to them too.
    We also had one specific model from them where the laser appeared to fail on every type of one model Brother HL-5170 or HL-5070 IIRC we purchased causing the print to become too faint and rendering the printers unusable after a couple of years (outside warranty). That was actually what prompted us to switch to HP!
    Maybe the solution, as others have suggested, is just to make a point of buying printers with extended warranties as without it you just seem to end up getting grief from management when they all start dying after a couple of years.
    Is it really asking too much to just have a printer brand that simply works without having models that all fail due to the same design fault 2-3 years down the line?
  9. #9
    Dec 2009
    Birmingham
    Quote Originally Posted by maniac View Post
    Cheers
    Mike.
    I have been able to source a spare formatter board with stock if that would be of any help for you?
    Cheers
    Toby
  10. #10
    Dec 2009
    london
    30
    11
    I had 4 out of 10 fail with the same fault - I would push hp for a part replacement even it's out of warranty - I think it's a known fault to them.
  11. #11
    Jan 2006
    104
    116
    Quote Originally Posted by 10101010 View Post
    I'd tend to agree but I've been finding the problem with HP support is you just end up getting put through to someone reading from a flowchart who's only resolution is to send a replacement printer with the same fault (in terms of our problems with P2055s). So far we've had no success speaking to anyone who can suggest anything more technical than simply holding the buttons on the printer to perform a factory reset.
    Unlike Dell/etc we don't have any kind of account manager who can take up the issue on our behalf. The compaines who we usually buy HP kit, and our account manager there, dont seem interested in dealing with the problem. At the end of the day it'll be their loss as we simply wont buy anymore HP kit in future.
    Are there any formal steps you can go through, or that anyone has had success with, in approaching HP to formally complain about hardware issues?
  12. #12
    Jan 2006
    104
    116
    Another (2 year old and out of warranty) HP P3005N Printer in our organisation is having what appear to be similar formatter board / memory issues to the above. Freezes and wont respond to anything either over the network or by pressing the buttons on the printer . Often takes 2-3 reboots to get it going and this is happening several times a day.
    That's nearly approaching a 50% failure rate in our school on this model of printer in only 2 years
  13. #13
    Mar 2010
    Sheffield
    7
    11
    We use Xerox Solid Ink printers on a 'pay per page' agreement. I'm really impressed, they print in wax, so they are greener than plastic toner printers.
    We pay less than 1p per mono page and 6p per colour page, regardless of coverage and this includes an indefinate service agreement, all consumables and warranty.
    The printers only cost us £350+VAT and do duplex colour at about 20ppm on a sprint (well half that in duplex). The only problem is the warm up time, they dump wax out the waste tray when you turn them on/off - but this doesn't matter if you've got an ultimited consumable page click agreement.
    (note I don't sell them)
    Last edited by PeteHopton; 9th April 2010 at 04:06 PM. Reason: making sure I don't get banned.
  14. #14
    networkingNut's Avatar
    Oct 2008
    Midlands
    15
    12
    We have three of of the 3005n's and they have all had the same formatter problem. I second the Extended warranty.
  15. #15
    Jan 2006
    104
    116
    Just phoned and HP have agreed to replace our faulty (2 year old and out of warranty) P3005 with a refurb unit. Apparantly there's a notice on their helpdesk to replace any printers with this particular fault even if they're out of warranty? Don't know how long this situation will last or if it covers every single P3005 but at least it looks like some may be replaced if they have the formatter board fault and are out of warranty?
  1. Dell Spare Parts
    By tech_guy in forum Hardware
    Last Post: 22nd February 2010, 12:54 PM
  2. Desk spare parts
    By m0nty in forum AV and Multimedia Related
    Last Post: 7th December 2009, 02:26 PM
  3. Spare Parts
    By witch in forum Recommended Suppliers
    Last Post: 3rd December 2009, 01:05 PM
  4. Prices for some spare parts (dell/toshiba)
    By dgsmith in forum Our Advertisers
    Last Post: 11th May 2009, 10:06 PM
  5. Spare Parts
    By Wildebeaste in forum Hardware
    Last Post: 21st August 2007, 08:19 AM
