Page 4 of 4 FirstFirst 1234
Results 46 to 50 of 50
Hardware Thread, Cooling fan with a difference in Technical; After a bit of googling it seems the 5-pin connector is Dell only... solution - multimeter one of the fans ...
  1. #46
    RinSewand's Avatar
    Apr 2009
    Wakefield
    14
    18
    After a bit of googling it seems the 5-pin connector is Dell only... solution - multimeter one of the fans (should be able to get a contact just inside the connector. Find 12v, spilce wires onto one of those 3 pin splitters - done!
    That way the Dell will still think it's got a proper fan plugged in (as aparently you have to hit F1 on boot if they don't) and you can splice on whatever fan catches your eye...
  2. #47
    Feb 2007
    East Sussex
    16
    30
    Why not replace the pc with an atom based pc - much less power and therefore going to run a lot cooler?
    If not how about one of the antec thermally controlled fans running off a 12v power supply? - It will only come on when its needed then?
    Steve
  3. #48
    theeldergeek
    Guest
    Quote Originally Posted by Sirbendy View Post
    What about getting the locker down to your DT Dept and getting some proper vents cut into it, then meshing it out?
    Another idea to consider, thanks.
  4. #49
    theeldergeek
    Guest
    Quote Originally Posted by contink View Post
    Dumb ass suggest I know but what's stopping you shutting down the PC and modifying the spare SATA power cable to turn it into a standard molex...
    There is no spare SATA, and what cable there is that we might splice off of, is about 1" in length, so there is no room for manoeuvre really. In addition, the machine is under warranty with Dell, so slicing connectors and cables up isn't really an option as it would undoubtedly invalidate our warranty.
  5. #50
    RinSewand's Avatar
    Apr 2009
    Wakefield
    14
    18
    Ahh, good point.
    SATA Power Extension Cable : Internal SATA Cables : Maplin
    Sata power cable extension? Splice into that?
  1. Server Room Cooling
    By Danlewis3 in forum Wireless Networks
    Last Post: 30th November 2009, 11:13 AM
  2. [Website] Tinchilla – Instantly Cooling Your Beer Cans in Only 60 Seconds
    By mattx in forum Jokes/Interweb Things
    Last Post: 13th June 2009, 10:44 PM
  3. VGA Cooling
    By Dos_Box in forum Hardware
    Last Post: 26th August 2008, 01:28 PM
  4. Artic-cooling Freezer CPU - FYI
    By contink in forum Hardware
    Last Post: 17th July 2006, 10:56 AM
