Results 1 to 7 of 7
Hardware Thread, Problem with HP universal print driver in Technical; Hi All, I'm having a problem with some printers on site, mainly HP 2015n's We are using the latest universal ...
    Oops_my_bad's Avatar
    Jan 2007
    Man chest hair
    438
    30
    Hi All,
    We are using the latest universal print driver (previously upgraded from older version to see if it causes a problem). Print server is 2003 R2 standard 64bit, but we are sharing out 32bit and x64 drivers for clients.
    When some people print a document, the text will print off OK but the images just come out as black squares!
    Clients are a mix of Vista and 7, all 32bit
    I can remove the printer off the client and reboot to let it re-deploy and it will work OK for a few days, until it starts printing the black squares again.
    Anyone ever had this or got any ideas what could be causing it? Driving me up the wall now!
    AngryTechnician's Avatar
    Oct 2008
    698
    394
    I have had no end of weird issues like this with the UPD, and have given up using it. One thing you could try is swapping from the PCL to the PS version (or vice-versa depending on which one you're using).
  3. Thanks to AngryTechnician from:
    Oops_my_bad (2nd March 2010)
  4. #3
    Fuzzz's Avatar
    Nov 2008
    Netherlands
    57
    13
    You can also use the driver for the HP LaserJet 4 Plus. Works with just about any type of printer. Only advanced options such as duplex printing (if supported by your printer) are not available.
  5. #4
    round2it's Avatar
    May 2009
    UK
    199
    38
    Quote Originally Posted by Fuzzz View Post
    i would go with ps drivers for hp printers
    also do you use pcounter by any chance?
  6. #5
    Gerry's Avatar
    Jun 2007
    North Wales
    60
    24
    I don't use the UPD's either, heard too many bad things about it. I mostly use PCL but some printers like CP1515 work better with PS.
  7. #6
    Jan 2007
    Man chest hair
    438
    30
    Okai. Well, I've loaded the latest universal PS driver on a small sample of printers on our print server. Bingo, the problem appears to have been sorted.
    However the problem I am having now is the speed of print jobs!! It is taking around 30 seconds for the job to actually spool up and hit the printer - small jobs, should print pretty much as soon as you hit print, and once it starts printing, the paper is so slow to move through the printer (eg the rollers seem to run at about half speed and the paper is very slow to come out of the output bin) So to print it is taking anything upto 1 or 2 minutes per page!
    As soon as I load the PCL drivers all is fine, except for the black boxes
    Anyone any idea why the PS driver may be causing this speed problem? I havent tried the B&W printers yet but this is ocurring on all our HP 2025N's
  8. #7
    SimpleSi's Avatar
    Jun 2005
    Lancashire
    1,476
    168
    See this thread which explains why PS is slow
    HP2605 printers soooo slow
    regards
    Simon
  9. Thanks to SimpleSi from:
    Oops_my_bad (11th March 2010)
  1. Pritnt watermarking/force print driver settings
    By Hacksawbob in forum How do you do....it?
    Last Post: 21st January 2009, 10:26 PM
  2. Replies: 4
    Last Post: 10th October 2008, 03:40 PM
  3. Terminal Serve and Print Driver
    By thegrassisgreener in forum Windows
    Last Post: 16th May 2008, 11:47 AM
  4. Replies: 11
    Last Post: 7th March 2008, 02:28 PM
  5. Universal Printer Driver
    By DaveP in forum Network and Classroom Management
    Last Post: 16th August 2007, 09:06 PM
