Results 1 to 6 of 6
Hardware Thread, Well Done TTS - Easi-Speak Pro Issue in Technical; I would like to so say a huge thank you to the support guys at TTS for sorting out an ...
    SYSMAN_MK's Avatar
    Sep 2005
    490
    429
    I would like to so say a huge thank you to the support guys at TTS for sorting out an issue I had with the Easi-Speak Pro. After getting a batch of 15 I was getting report of missing audio on recordings that only affected MP3s and not WAV files.
    After calling their support line I spoke to a very helpful chap who after trying a number of things sent a sample MP3 to their manufacturer who requested one of the Easi-Speak Pros for investigation.
    Well after the investigation by the manufacturer they supplied a new firmware and touch wood the issue has not re appeared.
    With permission I have attached the firmware if anyone else has encountered this problem.
    Jun 2010
    Ipswich Suffolk
    1
    Thanks very much - I've had the same problem with the Easi-Speak Pros my school received from the TESCO scheme - we've been using some basic Easi-Speaks for ages with no problem. TTS said they would replace the mics but haven't... Now all I need is some instructions for how to upgrade the firmware with the .rar file! In the meantime I'm recording in .wav format...
    SYSMAN_MK's Avatar
    Sep 2005
    490
    429
    I'll sort out a walk through tomorrow.
    Jun 2010
    Ipswich Suffolk
    1
    Brilliant! I'll look forward to getting it sorted...
    SYSMAN_MK's Avatar
    Sep 2005
    490
    429
    Just checked. Unzip the rar file, you will find revised formware and PDF with instructions on how to flash the easi-speaks.
  6. Thanks to SYSMAN_MK from:
    digitek (1st July 2010)
  7. #6
    Jun 2010
    Ipswich Suffolk
    1
    Brilliant - worked like a dream and so now does the mic. Thanks very much indeed!
  1. Easi-Scope
    By enjay in forum Hardware
    Last Post: 25th November 2010, 11:45 AM
  2. Display Issue Tosh Satellite Pro
    By witch in forum Hardware
    Last Post: 11th November 2009, 01:03 PM
  3. Paint Shop Pro 8 'Invalid Character' issue
    By detjo in forum Educational Software
    Last Post: 14th April 2008, 04:12 PM
  4. Adobe Acrobat 8 Pro patch issue
    By disk in forum Windows
    Last Post: 14th February 2008, 07:38 PM
  5. Think before you speak..
    By Gatt in forum Jokes/Interweb Things
    Last Post: 8th February 2007, 06:07 PM
