Results 1 to 6 of 6
Hardware Thread, Display Issue Tosh Satellite Pro in Technical; I hope someone has seen this because I never have - this is a teacher's laptop - very new - ...
    witch's Avatar
    Nov 2005
    Dorset
    738
    488
    I hope someone has seen this because I never have - this is a teacher's laptop - very new - connected to a Smart board. The screen on the laptop is fine, but when F5 is pressed and the option to display on the whiteboard AND the laptop is chosen, the icons on the laptop go all 'widescreen' and some things don't display well (they fall off the screen etc). The display settings do not change - 1024 by 768.
    Can anyone tell me why and if I can stop it?
    Ta
  2. IDG Tech News
  3. #2
    tmcd35's Avatar
    Jul 2005
    Norfolk
    9
    623
    166
    Is it a widescreen laptop? Are you sure the default res is 1024x768 on the laptop? My first guess would be the default res on the laptop is probably 1440x900 (a widescreen res) and when you switch to the projector the laptop switched to 1024x768 because that is what the projector supports. 1024x768 would look stretched on a widescreen display.
    My other thought was a widescreen projector doing something to the display?
  4. #3
    TheLibrarian
    Guest
    I've seen some of our Dell laptops do odd things when using the keyboard shortcuts to cloning the screen after image deployment (default driver configuration).
    Once we've use the display control panel to set the resolutions / aspect ratio / refresh rates the keyboard shortcuts seem to work fine.
    HTH.
  5. #4
    CESIL's Avatar
    Nov 2006
    Hampshire
    86
    132
    I would have to agree with tmcd35...
    Quote Originally Posted by tmcd35 View Post
    I have all our new Toshibas set to non-widescreen permanently 1024x768) just to try and avoid this issue...I don't think the staff have even noticed that the icons are a bit wider than they ought to be
  6. #5
    witch's Avatar
    Nov 2005
    Dorset
    738
    488
    NO - that's what I thought - but it is DEFINITELY set to 1024 x768 - I know this as we had issues with the projector displays and they had to be set to this otherwise the picture isnt the right size for the screen.
    I know it sounds odd.
    When the display is NOT shown on both laptop and screen (and yes, it is widescreen) there is no problem and no ' extra fat' icons, and it is set at 1024 x 768. Then when it shows on the screen and the icons are 'fat' the display is still set at 1024 x 768
    Any other ideas?
  7. #6
    witch's Avatar
    Nov 2005
    Dorset
    738
    488
    And in typical techie fashion - teacher turned it on today and alll is well!!!!!
    I don't know why but I am going to just creep quietly away.
    Thanks for the advice though - actually it helped me with another issue on a different projector, so it is all good!
  1. Toshiba Satellite Pro installing xp
    By mossj in forum Hardware
    Last Post: 2nd September 2009, 03:44 PM
  2. Tosh Sat Pro L10
    By kylewilliamson in forum General Chat
    Last Post: 10th March 2009, 09:54 AM
  3. Toshiba Satellite Pro 300
    By Maz in forum Hardware
    Last Post: 11th February 2009, 08:37 AM
  4. Toshiba Satellite Pro S300
    By northernrob in forum Hardware
    Last Post: 16th January 2009, 09:41 PM
  5. Toshiba Satellite Pro A100
    By pmassingham in forum Bad Experiences
    Last Post: 2nd May 2008, 07:46 AM
