Results 1 to 13 of 13
Hardware Thread, Portable Sound System in Technical; Hi, Apologies if there's already a similar thread, i couldn't see it! In our Hall and Gym we've got projectors ...
    Aug 2009
    Southampton
    In our Hall and Gym we've got projectors on trolleys that we wheel in and out as we need for assemblies and whatnot. However we need some new speakers for the laptops to connect to.
    We had some standard PC speakers sat on the bottom of the trolley in the past (as shown below), however they're a bit weak and dont have the volume we'd like. Also they keep falling off and are now damaged.
    We've looked about and cant really find anything that'll sit nicely on that bottom shelf. Anyone got any ideas?
    p858snake's Avatar
    Dec 2008
    Queensland
    37
    2
    51
    Does your hall have a pre-existing sound system that you use during assemblies and such? because it would be wiser most likely just to wire it into that.
    Oct 2006
    184
    148
    Budget?
    Ive not actually used them but when researching a similar situation for someone else i liked the look of this;
    MACKIE SRM 150 - 150 WATT ACTIVE SPEAKER- EACH
    Apr 2006
    Work-Blackburn,home-Preston UK
    6
    21
    Or these. I have these as monitors in the sound booth, but they are quite loud as a cheaper option. 2 for stereo obviously!
    http://www.soundslive.co.uk/product~...-3~ID~1655.asp
    pod
    pod is offline
    Feb 2009
    Belfast
    21
    Have you any old coombers? Our languages department had some laying around and we get good use out of them connecting them to laptops for classroom/hall use. They tend to give out a good bass sound.
  6. #6
    Apr 2009
    Leeds
    6
    13
    If your not bothered about stereo, we use one of these:
    Behringer K450FX ULTRATONE PA / Keyboard Amplifier | DV247
    You can connect a PC via the RCA sockets and/or a Microphone via XLR/normal jack lead.
  7. #7
    LeMarchand's Avatar
    Jan 2008
    The deepest pits of hell
    303
    141
    Won't fit on the bottom shelf, but might be useful for hall use anyway: starting 2/11 Lidl are doing a PA kit for £99.99:
    # - 2 x 8'' speakers
    # - 6-channel power mixer
    # - 2 speaker stands and mixer stand
    # - Microphone
    # - Cables
    # - Transport trolley
    # - And much more
    # Speakers:
    # - 100 watt max. output
    # - Frequency range: 60Hz - 20kHz
    # - Max. output level: 113 dB(A)
    # Power mixer:
    # - 2 x 100 watt (RMS) output
    # - 7-band equalizer
    # - Digital processor with 16 effects
    # 2 year manufacturer's warranty
    You could leave the kit set up and run a long cable from the trolley to the amp.
  8. 2 Thanks to LeMarchand:
    dhicks (29th October 2009), jinnantonnix (29th October 2009)
  9. #8
    Andrew_C's Avatar
    Sep 2005
    Winchester
    64
    159
    To really understand what you need, we would need to know how big the hall is (huge/small would do) how quiet the kids are and how loud you need the system to run, oh, and budget too!
    A 100W is not all that good an indication of how loud a system will be; efficiency is an important factor. Of the posts above; I'd look at the Mackie above the Lidl any day, but that is because I'd like it to work beyond the end of the week.
  10. #9
    Sep 2007
    UK
    1,436
    645
    This ION|TAILGATER|PORTABLE PA SYSTEM, WITH IPOD | CPC might be the answer. Very flexible and great if you have an ipod.
  11. #10
    mac_shinobi's Avatar
    Aug 2005
    3,265
    365
    I've got a set of AV40 studio phile M Audio speakers with a 1 year warranty ( if you have any issues call em and they will arrange to get them sent back and replaced ) as I did once and no issues or faffing around
    M-Audio Studiophile AV 40 Left / right CH speakers
    Pretty loud and work great although they do require mains power so not sure if thats an issue
  12. #11
    chrbb's Avatar
    Oct 2005
    Midlands
    141
    46
    We have exactly the same setup, with exactly the same problem! In fact I had to check your location in case I've got poster from my school
    We had a visit from our neighbouring senior school and they used Logitech Z 4 40 watt speakers which I'm told were quite loud enough, our hall is about the size of a badminton court.
    Having a bit of a rummage round in a store cupboard I came across a Carlsbro WANDERER PLUS BP Portable PA System so might have try with this to see if it's loud enough.
  13. #12
    3s-gtech's Avatar
    Mar 2009
    Wales
    145
    152
    In a large school hall, we used to use a pair of Edirol MA-7A speakers. They're very solid, can be mounted onto the trolley, and sounded pretty good in such a big space. They'd fit neatly on that shelf too.
  14. #13
    Nov 2009
    great! Thanks!
  1. GIMP Portable
    By cookie_monster in forum Windows
    Last Post: 20th October 2009, 10:04 AM
  2. PC Surround sound system and a TV
    By SimAda00 in forum AV and Multimedia Related
    Last Post: 5th August 2009, 08:04 AM
  3. Frontrow sound system
    By Jobos in forum General Chat
    Last Post: 28th August 2008, 10:48 AM
  4. Portable Projector
    By Stevenw in forum Hardware
    Last Post: 7th May 2008, 01:59 PM
  5. Portable Apps
    By Heebeejeebee in forum Downloads
    Last Post: 25th November 2006, 10:06 PM
