Hardware Thread, Help me find a mains cable for an APC rack UPS in Technical; I have just been given one of these:
http://www.apcc.com/resource/include...u=SUA3000RMI2U
And need a power (mains) cable. These are not a standard ...
3rd October 2006, 11:03 AM #1 Help me find a mains cable for an APC rack UPS
And need a power (mains) cable. These are not a standard type and all I can find is an 'uplink' daisychain one. Can anyone recommend a supplier or point me in the right direction for getting it connected to the mains please.
IDG Tech News
3rd October 2006, 11:11 AM #2 Re: Help me find a mains cable for an APC rack UPS
3rd October 2006, 11:12 AM #3 Re: Help me find a mains cable for an APC rack UPS
That's the one APC site says the C19 connector is rated for 16amps.
http://www.lindy.com/uk/productfolde...0339/index.php
£9.99
3rd October 2006, 11:14 AM #4 Re: Help me find a mains cable for an APC rack UPS
3rd October 2006, 11:14 AM #5 Re: Help me find a mains cable for an APC rack UPS
That's a 16amp I think. Not sure if you need to have a 16amp ring main to plug it in to?
Wes
3rd October 2006, 11:15 AM #6 Re: Help me find a mains cable for an APC rack UPS
3rd October 2006, 11:19 AM #7 Re: Help me find a mains cable for an APC rack UPS
Found this its made by HP worth investigating as its alot cheaper http://www.pcwb.com/catalogue/item/C...e&lead=froogle
3rd October 2006, 03:31 PM #8 Re: Help me find a mains cable for an APC rack UPS
Originally Posted by
wesleyw That's a 16amp I think. Not sure if you need to have a 16amp ring main to plug it in to?
Ring mains are 30/32A, used with fused (13A) plugs. If you want to draw the full 16A, you need a radial circuit breakered at 16A wired in at least 1.5mm cable, probably 2.5mm, depending on details.
3rd October 2006, 03:47 PM #9 Re: Help me find a mains cable for an APC rack UPS
That isn't a plug to a C19 connector though but a C14 which is normal pc type IEC connector.
3rd October 2006, 09:22 PM #10 Re: Help me find a mains cable for an APC rack UPS
Its the C19 one as far as I remembered from when I fitted my one of that UPS. (If you are being given any more, I will take 5 please
3rd October 2006, 10:11 PM #11 Re: Help me find a mains cable for an APC rack UPS
Yes it's a C19 he's after I was saying that the previous link to a product given wasn't as suitable as the others.
3rd October 2006, 10:59 PM #12 Re: Help me find a mains cable for an APC rack UPS
If by UPLINK cable you mean a C19 to C20 cable, and you need a cable quickly. Chop off one end and fit a 13 A plug.
Unless of course H&S wouldn't allow that
I think you can still buy 13A plugs !
I don't think you need to worry about ring mains, etc., etc.
A ring main can actually supply up to 30-32A, but under the IEEE regulations all outlets should be fused to 13A max. It is the total for the ring which should not exceed 30-32A.
13A @ 230V would allow up to 2990W which is above the 2700W rating.
I think the 16A is the cable rating and not the supply requirement.
The spec doesn't actually give the input power, which will be higher than 2700W, but I am sure it will be within 13A, and is usually stamped by the input connector.
Beyond that spec you would need a hard wired supply, say 40A, or even a 3-phase supply to the UPS, like in the good old days of IBM Mini's and Mainframes, etc, etc.
I think I would go for the:
rather than mess about with mixing in C14 connectors.
Although you probably have loads of old PC power cables stashed somewhere, like the rest of us
Just shows if you shop around, what you can save though ...
4th October 2006, 07:39 AM #13 Re: Help me find a mains cable for an APC rack UPS
Yeah our UPS is wired directly to a three phase supply.
Wes
1st May 2007, 12:13 PM #14 Re: Help me find a mains cable for an APC rack UPS
Dos_box: Did you get a cable for this in the end as I'm now going for a 5000va ups for all my servers and need the same thing at the moment until I get a spark to wire it in for me.
1st May 2007, 12:48 PM #15 Re: Help me find a mains cable for an APC rack UPS
If its an APC 5000VA, then the C19s are outputs, the ups has to be hard wired (the only connection on the back is two terminals behind a plate). You might reach a compromise like I did by using a big locking 3 pin connector (mine runs of a 32A 3 phase supply).
By strawberry in forum Hardware
Last Post: 6th December 2007, 07:11 PM
By cooper in forum Recommended Suppliers
Last Post: 25th July 2007, 12:31 PM
By ict-direct in forum Our Advertisers
Last Post: 24th July 2007, 11:29 PM
By MrMez in forum Hardware
Last Post: 27th June 2007, 08:16 AM
By tosca925 in forum Hardware
Last Post: 22nd May 2007, 08:32 PM
- You may not post replies
- You may not edit your posts
Forum Rules
